Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge profile 2004
My refer door does not close tight anymore. i don't hear the suction like i do on the freezer side. we did have a rat that was living in there and chewing things up do you think he chewed a hose or wire or is it possible that i didn't level it correctly during install and the alignment is off?
  • 833 Answers
First, the unit should be installed so that the floor is level and even. If not, the door cannot close properly because the cabinet will be distorted. There are some adjustments which can be made according the the manual. Make them. Second, look at the door itself. If the gasket is distorted or damaged by the rodent or it is dried out or ripped, you'll have to replace what's damaged. Check that the hinges are properly installed and tight. The door should swing freely. There is generally nothing inside the door which should interfere with it closing properly however, if you've overloaded the bins, it could interfere.
Posted on Dec 13, 2007
GE Profile side by side refrigerator. The freezer side started to have leakage and caused frozen ice along the walls & Extreme suction on freezer side.
Not sure on this one, but many freezers draw a vacuum like that for a little while to try to get all of the air and moisture out. Commercial units are designed that way. If Ice is building up, there is most likely an air leak. Check the door gaskets and see if they are sealing up properly.
Aug 02, 2016 | GE Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
GE Profile door
lose the top hinge and pull the door just a bit. then re thigh the hinge on the new position.
Dec 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 02, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
High pitch noise from GE Profile Refer
get your cam corder and record it show it to your repair man
Mar 15, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
63 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
