Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7310 print cartridge
I have installed a new color and bw cartridge. Completed printer aligment and all. Now everytime I print something I get a thank you message for using HP products for the BW, the Color, and the photo. I called tech support and they had me remove cartrides, shut down printer, restart printer, reinstall cartridges and t his fixed the problem, however the next day turn on computer same problem. I went through the fix routine again and now it won't fix this. Tech support said no warranty on cartridtged, my local offic esupply replaced the two and the two new ones are dong the same thing.
Any suggestions for a fix.
    Novelist:
  • 79 Answers
As u have already tried a few steps and repalced teh carridges as well, u can try the following steps as well .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Thanks
Posted on May 27, 2008
I have an hp deskjet 940c. the colored ink is out but there is plenty of black ink however the ink light is flashing and it wont print. do I need to replace the colored ink in order to print something or...
You will need to replace the empty color cartridge to get the flashing to stop.
However you should still be able to print in BW. Check that the applications you are running are set to
BW and not color in the configuration menu. That should permit you to print in BW only.
Mar 22, 2011 | HP DeskJet 940c InkJet Printer
I installed an Hp Color cartridge on my C7250 it is not recognizing it.
If it is not an original hp cartridge try original cartridge!
If it is an original hp cartridge you probably need a new print head.
Nov 23, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I reset a re-filled HP97 tri-color printer cartridge for an HP 7310 all-in-one printer. I have re-filled the cartridge at walgreens, re-installed the re-filled cartridge, but the diagnostic still...
if it continues to show "empty cartridge" that means. the printer is not accepting the refilled cartridges..
You will have to try with a new genuine HP ink cartridge.
Oct 13, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Printer won't print in color and I just installed a new color cartridge.
Go to the control panel > Printers. Open the 7310xi and go to settings or printer properties. Go to the color tab at the top. There is a box marked "print in Grayscale" make sure this in UNCHECKED. Try printing out a test page.
Jan 07, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How to stop printing test page every time I turn on my printer
This is an aligment page.When printer print the page just follow the instruction on page put it on the scanner glass and finish the aligment.If your color or/and black cartridge is empty or clogged the aligment is not compete and printer will print this page every time when you turning it on.If your case is that just replace the cartridge and finish the aligment.
Nov 04, 2009 | HP PSC 1410v All-in-One Printer
Hp 7310 printing with color horizontal streaks across. parts of the artwork are fine, then strirated lines down whole page. changed cartridge color and b/w and says it's installed fine. test page is...
usually when there is a defect on printing out while you have changed the cartridges , you will need to consider changing the printheads of that printer.
Aug 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Print cartridge has a problem
try to check the ink cartridge that u use...it is match with your printer or not?
May 26, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer tells me to install new color cart. after i have put in new hp cart.
1. Press the Setup button.
  1. Use the arrow keys to select Tools and then press the OK button.
  2. Select Clean Print Cartridge and then press OK . The device prints a test page.
  3. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  4. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
  5. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
  6. Remove and re-insert, while the product is switched on.
If still bad, swap out the cartridge.
Hope this helps
Regards
Apr 19, 2009 | HP Officejet 7310 All-In-One Printer
Hp 7310 all in one
First check that printer is not set to print B&W. Open an application to print a page, for example Word. Chose print command from the file menu on top bar , the print window will open.
In the print window press the 'properties' button, and check tha printer is set for color printing.t
Once you are sure printer settings are not in B&W, read the following.
Even if it shows color at 75, the printer color level may had not been reset since the cartridge had been replaced, in this case the cartridge may be empty.
If the cartridge is not empty it still can be faulty (eg. ink insid is dry).
In either case replace color cartridge with new original one.
If after you replace the cartridge it still does not print colors, then color head is faulty, at this point consider having the printer repaired by a technician.
Jul 22, 2008 | HP Officejet 7310 All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
