Question about Mitsubishi ES100U Multimedia Projector
Projector cutting off
I have the Projector hooked up to a PC, the projector loads up and does everything as normal. But after 3 - 4 minutes of working perfectly the projector shuts off and powers down. Nothing has changed on the settings or how its wired. Any suggestions on what I could possibly do.
  • 1 more comment
  • Anonymous Sep 30, 2008
    Same problem here.
  • Anonymous Dec 08, 2008
    I have the same problem...
  • harrisa383 Apr 03, 2009
    same problem AND I bought a new bulb. No help at all.
Read the manual?
Posted on Feb 15, 2008
My TDP-P75 toshiba projector keeps cutting out for no reason - any advice anyone?
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Dec 08, 2012 | Toshiba TDP-S8 Multimedia Projector
Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After ...
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Nov 15, 2010 | Televison & Video
Projector keeps cutting off
just in case it is overheating, blow out any dust with canned air and make sure the fans are working. also, keep anything from blocking the vents. if all that is done and it still shuts down, you have a power supply that needs replacing.
Nov 04, 2009 | Optoma MovieTime DV10 Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
No image
Mar 06, 2008 | Epson - PowerLite S1+ Multimedia Projector
Check to see if the fans are working, you should feel and hear the air coming out of the front grill. The best thing is to operate the projector with the top cover removed. See previous posts.
Jan 08, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
Displayed massege to check air flow
With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
Oct 02, 2006 | Hitachi CP-S240 Multimedia Projector
Mitsubishi ES100U Multimedia Projector Logo
465 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
