Question about Denon AVR-2807 Receiver
Video signal loss
I'm running a Denon 2807 and displaying through a dell projector via component cables. When watching a movie or a satellite and an intense whit scene is demanded the video signal gets dropped for an instant then recovers. I thought it would be my projector but tried by-passing the amp and it worked fine. And also if I use S-video through the amp it works fine.
Any thoughts?
  • Anonymous Dec 13, 2007
    Same problem here.
  • Dokimon123 Jan 06, 2008
    Try turn on and off some lights in your house to see if you have the same problem. You may experience instant loss of sound
Try turn on and off the lights to see if you have the same problems. You may have instant loss of sound!!!
Posted on Jan 06, 2008
Why does our rear-screen projector (LG BG650/BG630) repeatedly shut down while showing movies?
PDF]User Manual - Projector Central
www.projectorcentral.com/pdf/projector_manual_7815.pdf
Owner's Manual. LCD PROJECTOR. BG630. BG650. Please read the safety ... DivX Video-on-Demand (VOD) movies. ... The product images and On-Screen Display (OSD) in this manual are ..... Turn off power to the lamp and cool down the lamp. ..... 2 After running the WiDi program on your notebook, a list will show all ...
LG BD630: Network Blu-ray Discâ„¢ Player ' LG USA
www.lg.com > Home > Home Video > LG BD630
LG ElectronicsGet information on the LG BD630. ... Component Video Out, 1 (Rear) ... on a big screenunder the stars, our home video players give you the ability to do it all. ... you can not only use your home video player to watch movies from a disc, but ... Projectors: Watch movies outdoors, show a photo montage on your living room wall ...Missing: bg650
Portable LED Projector with Built-in Digital TV Tuner - LG.com
www.lg.com > Home > Home Video > LG PB63U
LG Electronics
Dec 21, 2015 | Office Equipment & Supplies
My denon avr-2807 sound is studdering as the
sounds like a loose cable to me probably component. trace and replace.
Chris B
PHTBA
Feb 18, 2010 | Denon AVR-2807 Receiver
I have a denon avr-2807 receiver. on tv mode, i can only get analog signals. i am using an optical cable and the signal is only transmitted in digital. how can i correct this?
An optical cable is digital but its only audio not video. Are you connected to a cable or satellite box, are you using composit video, s-vid, component video, or hdmi? What kind of cable goes from your denon to your tv?
Aug 19, 2009 | Denon AVR-2807 Receiver
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
Denon 1905/785 - lost color feeding tv
Your Denon 1905 might be setting it under HDMI for video source.You need to correct it by going to menu,as you browse through the setting,you should able to find video select or video output. It is on the manual.
Remember,you need to run a composite video cable from the video output behind your receiver to your TV video input for this step.
solutiondoct
Mar 09, 2008 | Denon AVR-2807 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Denon AVR-2807 Receiver Logo
100 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
