Question about ViewSonic N3251w 32 in. LCD HDTV
Remove back panel
Hello, I have a tech that cant seem to figure out how to remove the back panel of the viewsonic N3251W - I am looking for any instruction on how this is done.
You have to remove the base at the bottom (4 screws), all the screws on the back, then use a thin flat-head screwdriver or other thin brybar and work around the back panel unlatching the snaps that are in place.
After the back cover is off, the metal cover over the board and power supply can be removed by removing the screws around the outside lip of the cover, along with the screws on the bottom and right hand lip of the raised area in the back.
Hope this helps.
Posted on Jan 08, 2008
  • benjamin_pez Jan 22, 2011
    I completely recommend the household butter knife for prying open the back. It left much less damage than the flat head screwdriver.
    I completely recommend the use of kitchen butter knifes as pry bars to get the back off. They seemed to leave much less damage and give much better leverage on my 32" model after nearly four years of reliable service.
There are 4 screws and many clips all around, with a flat head screwdriver you can pry them open and just keep holding it open while you pry the clips open around the TV. Should come off with no plm.
Posted on Jun 19, 2008
No sound, fuse on power supply is white, picture fine
Viewsonic has a tech line: 1-800-688-6688
Credit: RepairWorld http://www.repairworld.com
Aug 16, 2011 | ViewSonic N3251w 32 in. LCD HDTV
Won't turn on
Lots of power supply issues with Viewsonics. Out of warranty? Open up the back and have a look at the power supply if you know something about electronics, otherwise, call a repair shop.
Apr 23, 2010 | ViewSonic N3251w 32 in. LCD HDTV
I have a viewsonic n3251w with no power at all, before it broke.. once in a while when I try to turn the tv on it wont turn at all but after a few try i can the tv turn on...so my question should i replace...
Your problem really does sound like a capacitor problem, some brands of caps will fail without any visible signs of failure. If you can post a picture or two or the power supply board to our tech site at: http://www.ccl-la.com/forum/index.php our techs will look over the board and get back with you on te steps to take it get it repaired. If you don' want to do the repair yourself we do offer a repair service, you can get more information about it here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | ViewSonic N3251w 32 in. LCD HDTV
I was away for 2 days , came home and there is NO power to my Viewsonic
Check outlet, then look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | ViewSonic N3251w 32 in. LCD HDTV
My Viewsonic N3251w has no power
Ur power ic converter board is dead.
U need a new one.
Aug 19, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Viewsonic N3251w 32inch LCDTV that does not have
It's most likely a capacitor. Open up your television, and look at your power circuit board. Look to see if any of the capacitors are blown.(the will be bulging look up an image of a blown capacitor to get a better image if not known already. Mine was (CS19, CS21, CS22, CS23) Also on (C672) from the Circuit Board.Can you look at the voltages of these for me? I'm missing the capacitors.
May 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
ViewSonic TV sound but no picture
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
Jul 29, 2008 | ViewSonic N3251w 32 in. LCD HDTV
ViewSonic N3251w 32 in. LCD HDTV Logo
1,279 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
