Question about Canon LaserClass 2060P Plain Paper Fax
Canon fax 2060P not recieving faxes
We have a canon fax 2060P that sends faxes but will not recieve, it rings and the display says recieve (not recieving like it does when it is working) Any ideas are greatly appreciated.
thanks
  • 4 Answers
It sound like your machine is set to answer in manual mode. should be button on cotrol panel to set answer mode. when it in manual mode fax will ring but nothing happens till you hit start button.
Posted on Oct 01, 2008
    Scholar:
  • 159 Answers
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Posted on Feb 27, 2008
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon LASER CLASS 2060P
we should 1st go to cannon.com download your latest driver over using cd one ok manaul is also n ther web site so do that 1st download latest driver for xp or vista whatever u may need form www.cannon.com k thx nick
Oct 06, 2008 | Canon FAX-L360 Plain Paper Laser
CAN'T RECIEVE FAXS
Make sure the Auto answer the button is on....
Or
Reset the printer setting to default and set the rings again to 3...and try..
Jun 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
MaggieB
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Canon LaserClass 2060P Plain Paper Fax Logo
142 people viewed this question
old marine
old marine
