Question about Video Cameras
F 02 fault in Panasonic NV-S85B
I have just got my camcorder out to playback some tapes prior to editing them and converting the results to DVD.
I am getting a F 02 fault and the picture, when it does run, is very jittery,
I have given it a blow out with 'Clean-Aer', and tried to run my Scotch cleaning tape to no avail.
Anything I can do or is this a workshop job.
BTW, I last used the camcorder in Singapore about 2 years ago.
4 Suggested Answers
SOURCE: Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. jinn666@hotmail.com
Posted on Jul 29, 2007
SOURCE: no video or audio in playback mode
I Had a similar problem with my 8600. Most likely the camera
is also no longer recording. There were two problems I found,
either one could have caused the problem. 1) the 8mm tape was not
actually moving through the record/play head. With modern cameras. there are no indications that the tape is actually moving.
2) the record/play head is dirty. What I did was remove the
side plate that covers the tape cassette to allow me to verify that
the tape was moving properly. After that, I removed the tape, removed the battery, and used isopropyl alcohol and a q tip
to clean the head. I imagine there are cleaning tapes that one
can buy to do this as well. though I doubt they work as well as
a q tip. THere are two screws that hold the cover on.
Posted on Feb 21, 2008
kevin000
  • 1847 Answers
SOURCE: No sound on tape playback.
Are you using the sony software to download and convert the video?
Posted on Sep 08, 2008
Which firewire cable for panasonic NV-GS4
You need a 6pin DIN to firewire convertor, or to USB.
Checkout fleabay.
Oct 01, 2017 | Panasonic NV-GS40 Mini DV Digital...
How do i download my tape to my computer so i can put the images on dvd. my camcorder is an old panasonic nv-rx10eg with a small cassette
Install a capture card (Firewire card) in PCI slot.
Install a video editing software in PC.
Capture video in PC and edit as per requirement.
Go to 'share' or 'make movie' option to render the edited video.
Make DVD with that rendered file.
Thank you,
Gautam Kumar Mandal, M.Tech.
Addl. Chief Industrial Engineer,
Durgapur Steel Plant,
Steel Authority of India Ltd. (SAIL).
Mar 08, 2010 | Panasonic NV-MD10000 Camcorder
Panasonic NV-GS27 playback
you can playback only when you connect it to a pc tv tuner card. or other video editing or capturing software installed for camera
Jul 01, 2009 | Panasonic NV-GS27 Mini DV Digital...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Jul 03, 2008 | Panasonic NV-GS17 Mini DV Digital...
Camcorder is dead - power supply not to blame.
Intermittent fault? Playback of recorded footage not possible.
Even tried to check 'playback' with an older tape.
Jun 23, 2008 | Panasonic NV-MX350B Mini DV Digital...
Panasonic NV-DS27 - "playback blank"
try to clean the video head using a blank new tape and fast forward it 5 times if needed...dont use a video cassette cleaner it will ruin your video head...
Aug 01, 2007 | Panasonic NV-DS27B Mini DV Digital...
Video Cameras Logo
88 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
