Question about Sub-Zero 642
Sub-zero door seal
I have a SubZero 650 and the freezer door keeps "sticking" due to ice. I think it needs a new seal around the door. Can I order the seal and install myself?
  • 71 Answers
THE TRUE IS .. replace a door seal is a little pain to replace. YOU HAVE TO INSTALL RIGHT. ( some model using silicon. if you are patient. and able to remove aroun 30 screws. do it. if not. better call a tech........good luck.............................. LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Posted on Apr 02, 2010
Subzero regrigerator door not closing properly
Is it possible to elaborate a bit? Is it sticking? Jamming? Slamming? Not staying closed or sealed? Most of the time problems arise from damage to the white rubber seal (subzero's are specially fitted to ensure a stellar seal). Check along the entire rectangle surface for any cuts or problem areas.
Aug 16, 2014 | Sub-Zero 650 / O Bottom Freezer...
How do I turn off one of my subzero freezers? The door is frozen shut:)
YOU probably need to unplug it for about an hour and with a hair dryer go around the seal this mite take some persuading.
Dec 16, 2012 | Sub-Zero 650 / O Bottom Freezer...
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
Subzero refrigerator is not cold. freezer is fin
you could have a leak in the sealed system,most likely the evap coil.in the fridge section,is there any ice on the left side back wall?look at the back wall on the left side around 12 inches up from the bottom draws,if there's ice there you have a freeon leak and you'll need it replaced.look at your warranty,i believe the sealed system is under warrany for the first 12 years and it's around 650 dollars to do the job.there are two compressors,one for the freezer and one for the fridge.also open the door,you'll see tow switches on top,push them in,does the lights go out and the fan come on,i've seen the light switches stick,the lights stay on and the fridge gets very warm.how old is it?if it's digital is it saying to clean the coil or anything like this?
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
My model 650 subzero ice maker won't make ice after cleaning out freezer drawer
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero paint peeling
I have found no fix for this. I have tried repainting but it is not long before the paint is falling off again. Get ahold of sub-zero and tell them of the problem.
Jan 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 550 Frost Build up in Refrigerator
This means you are low on freon. You will get an ice ball on the bottom left side in the back of refer.
dartmanc
May 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
484 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
