You can see an easy step-by-step guide to programming your remote right on your TV screen:
Press
MENU on your remote control
Select Settings & Help
Select Settings
Select Remote Control
Select Program Remote and follow the on-screen prompts
You can also use the manual method below:
Make sure your TV and your receiver are both on.
Use this
tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV.
Slide the MODE switch on your remote control to the TV position.
Press and hold the
MUTE and
SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons.
Using the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice.
Aim the remote at your TV and press the
VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try
scanning for additional codes. If one of the codes worked, proceed to the next step.
Press and hold
MUTE and
SELECT buttons until the green light at the top of your remote control flashes twice.
Enter 9-6-0 using the keypad on the remote control. The green light should flash twice again.
Slide the MODE switch on your remote control to the DIRECTV position.
Follow these steps to scan for additional TV codes using your DIRECTV remote:
Slide the MODE switch on your remote control all the way to the right to the TV position.
Press and hold the
MUTE and
Using the number buttons, enter 9-9-1. The green light on your remote should flash twice.
CHAN/PAGE UP button. Tap the
CHAN/PAGE UP button repeatedly until the TV powers off.
When the TV powers off, press and release the
SELECT button.
Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
troylove11, I was playing around with the expert search. I am an expert there. Nevermind.
HELLO i NEED HELP i HAVE A MITSUBISHI WS-65513 AND HAVE THE GREEN LIGHT FLASHING DISORDER. tHE TV JUST WONT START AND THAT LIGHT NEVER STOPS FLASHING!!! my e-mail is [email protected]
I have the same Green light flashing can anybody email me how to fix this my email is [email protected] Thank you
i have a mitsubishi1800 hdtv an it woked fine.but now i have the green light blinking an it wont do anything else.i was hopeing someone knows how to fix this. ive tried reset ,unplugging ,thanx in advance, if you know email [email protected]
Email is: [email protected]
Green blinking light for days.....
Mitsubishi Model WS-65813, Serial #109690
have the same thing- can u help techman?
I have an DAEWOO 47" projection TV, and it's been taking awhile for it to come on, The power button ("not main power button") would click on and off and the tv won't come on at all now. and sence I moved, the sides of the screen The picture bow's in alittle. When you turn it on the led light is green and after a few seconds the tv clicks and the light turns red and it just keeps doing that. The model # is DSJ-4710CRA "Please help"
Craig
My E-mail is [email protected]
my green light on my mistubishi 55 inch ws-55859 just keeps blinking..what do i do to get my tv to go on again?
