Question about Dryers
Hotpoint dryer my dryer was running, then quit. it will not start, repalced timmer switch, still wont do anything. belt and drum both turn by hand. outlet has power.
    Problem Solver:
  • 9 Answers
Try the micro switch in the door this may not be making a conection or the capasitor may have gone this is the round barrel shpe thing with2or 3 wires connected to it this makes the drum start and stop and change directions
Posted on Dec 06, 2007
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Drum wont move
you should take off the bottom panel on the front of the dryer. there is usually 2 screws on the bottom. from there, you will be able to see if the belt is on and if you move the drum with your hand as you look inside, you will see if the belt is moving like it should
Oct 27, 2008 | Hotpoint Dryers
Dryers Logo
157 people viewed this question
Top Dryers Experts
