Question about Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200)
Trying to set up pptp on a Paradyne 6381
Everytime we try an connect we get error 800, cannot reach server. We have opened vpn for each pc on the lan, and we are using static ip.
  • Mister Chin May 11, 2010
    Also you could try and "ping" the hostname or ip address of the computer that you are trying connect to.
    What are you trying to connect to?
    go to start menu --> run --> type "cmd.exe" in
    the text field (a black window should pop up) --> in the black
    window type "ping" (it will send a ping packet to and you will receive some replys if you are connected )
I have modem 6381-A2-200, sw ver.03.00.10. As far as I know this model does not support pptp-connection.
Posted on May 21, 2008
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
How to setup VPN on iPod?
connect to WiFi.
Tap General>Network>VPN>
you can try these settings I've used before:
Add VPN Connection. chose PPTP.
Give it a name under description.
Encryption Level:Auto
Send all traffic: ON
Proxy: Off
Here's the part that differs from the VPN I personally set up.
Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want.
Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use.
The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
Jan 21, 2015 | Apple iPod Audio Players & Recorders
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
Adsl connection
The error Destination not reachable is due to a router not having a route in its routing table; to fix it I suggest consulting your documentation and/or using the admin console and its built-in help to add the route you need to its table. Note that 192.1.1.x is unreachable from 192.1.2.x LAN segment. Not familiar with Paradyne routing syntax, so I would try their web site if available for full details. If you can be more specific about the IP addresses (subnets, they're called) in question, I can provide more info. as to how its done.
Apr 07, 2009 | Paradyne ADSL/R 6381 Router (6381-a2-200)
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to:
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
Mar 16, 2009 | Cisco PIX 501 Firewall
How to configure my paradyne 6381 router
Go under LAN setup and enable NAT and Firewall services. Then go to LAN configuration to enable the dhcp server. Set the Start IP range and ending address.
Feb 24, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
2wire 1701HG Gateway Router VPN Setup
Go to and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the or schemes by accessing, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Jan 30, 2008 | 2wire (1000-400108-001) Router
6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
Nov 22, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200) Logo
146 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
