T.V. I turned on my Panasonic T.V. Model CT32SL13G and it was completely dead. Through research it appears that the fuse has blown from the start button. I have no idea how to replace the fuse and where to purchase it. Any suggestions
  • 2 more comments
  • avneet Jan 01, 2008
    I have the exact same problem, I just need to know where the fuse is so that I can change it myself.
    Please help
  • Anonymous Feb 17, 2008
    Ditto, turned on one morning, heard a single click and nothing else.  Called 3 shops, all told me it is some "common problem with the circuit board that requires a kit" and to expect a repair bill between $175  and $300.
    I want to check the fuse myself before I send it off.  Panasonic microwave did this last year, I paid $50 for diagnostic and the guy had the nerve to charge me for the $2 fuse on top.  It took him longer to write the service ticket than it took to make the repair.
  • Anonymous Mar 15, 2008
    sould I try a higher amparge is this safe
  • photosbyjc May 26, 2008
    I too have the same problem, where is the fuse, and what does it look like?
Check the fuse.
Posted on Dec 06, 2007
PANASONIC CT32SL13G - 32" TV
Hello:
There is some busted parts in your circuit board, you should examine the circuit for busted resistor and regulator. if afraid doing the task maybe you should let the repairman to do it for you.
May this help.
best regards melnavz.
Feb 21, 2008 | Hitachi 46F510 46" Projection HDTV
Scooter won't start
hi, so has the fuse blown again ???
Regards
Rob
www.gewizrepairs.co.uk
Mar 11, 2014 | Pride Go Go Elite Traveller Plus HD 4...
Dead Set
Could also mean a blown fuse in power supply. Fuse needs checking first if it keeps blowing then yes could be regulator, filter cap or rectifier diode fault
Jan 06, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Dead, replaced battery and still dead
your fuse is blown near the battery is a fuse check if it is blown
Jul 24, 2009 | 1995 Suzuki VS 800 Intruder
Power just quit had a great picture
panasonic tv's suffered from frame chip problems causing them to be stuck in stand by .not an expensive part though...
Apr 25, 2009 | Panasonic CT-32SL14 32" TV
Blawn AC fuse
Almost every modern set will just go into power supply shutdown if the horizontal output transistor is bad or other problems place a heavy load on the secondary side of the supply. Usually that results in a ticking or whistling from the set, but it won't blow the main fuse. A blown fuse typically means shorted parts in the primary side of the power supply.
The switching supplies used in today's sets can be a real pain. Check for a shorted input bridge rectifier or shorted switching transistors. There are also optical isolators used to provide control feedback and they can go bad, causing the supply to run away and blow up parts. A service manual or at least schematic diagram is very helpful. You might be able to find one online. I've checked my files and I don't have anything for the chassis used in this set.
Apr 01, 2009 | Panasonic Televison & Video
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Jul 29, 2008 | Panasonic Microwave Ovens
Very old Jenn-Air wall oven (model w100) will not heat
nope..no fuses...time to research a new oven.
May 28, 2008 | Jenn-Air Ovens
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
