Question about Microsoft Xbox 360 Console
Disk tray won't open
It doesn't open how do i fix it please
  • BlazenBeaver Dec 06, 2007
    I can open my disk tray when my xbox is on its side but it wont close. I can only close it by turning it upright but when i try to open it while its upright it gets stuck and wont open.
  • 3 Answers
I had this problem with my first console...
When i pressed the Eject button the tray didnt always came out.
Solution 1: Try moving the tray left and right (or up and down if you have your console vertical) imediatelly after pushing the eject button applying a bit of pressure ... and when you feel the tray pushing back... well, let it :)
Solution 2: (worked permanently for me): With FINE sandpaper rub out all the little edges around the inner part of the Tray´s Faceplate, on MY console the problem was a little edge of excess plastic, so i noticed easily...)
Hope this helps...
Posted on Dec 06, 2007
    New Friend:
  • 133 Answers
Call Customer Support: 1-800-4MY-XBOX
2 Suggested Answers
brianw74
  • 400 Answers
SOURCE: My X-Box 360 won't read my games all I get is open tray or unreckonized disk how can i fix it?
That is your drive thats crapped out....if you put in a game and it says open tray, time for a new disk drive or another 360....sorry
Posted on May 03, 2012
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
May 02, 2012 | Microsoft (X-Box) B4J-00107 X360 Platinum...
Repair guides
Hello, well rather than type out and try to explain the whole process, i will direct you to here and here. So much easier to "see" it than "read" it. The first link is for a tray that won't open. The second link is if the system actually says that it's reading the disk and the displays "tray open" message error. Both are common and very annoying. I have fixed many using both methods. If anyone is unfamiliar with how to open your xbox 360, you can watch how here. I hope this helps.
Dec 11, 2011 | Microsoft XBOX 360 ARCADE Console
The disc tray on my iView 4000KR won't open. It has a disc inside that plays fine, but won't eject. This has never happened in the 18 months I've had the player.
Under each disk tray is a very small hole; this hole is for use when you experience the problem like yours.
Get a paper/money clip and straighten the wire; push the wire into this hole and your disk will open.
Regards
HCF
Jun 22, 2011 | Computers & Internet
Phillips dvd player disc draw won"t open help
Usually, there's a pin hole beneath the tray that come out. If there is a pin hole, get a paper clip or safety pin and insert the pin or clip into the pin hole and push. That should pop the disk tray out.
Mar 21, 2011 | Philips Electronics - Others
Sony PlayStation 2 Slim disk only spins if door is a little bit open, I even put something on it so that it won open or shuts completely, because if it does, then it doesn't work,for reference, it was...
tray problem can be solved by opening the ps2
1. unscrew all the screw open the body
2. on the upper body u can see a spring on the tray
just clean the spring (dust particles)
3.cover the tray check whether it is working
Mar 22, 2010 | Sony PlayStation 2 (PS2) Console
Dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Jan 27, 2009 | Lite On LDW-401S DVD+RW Burner
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Microsoft Xbox 360 Console Logo
373 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
