900-4in1-align cart.message I have a 4 in 1, 900 series. I replaced the ink cart.& realigned,The realign message continues. I have shut down power left off for days ,reconnected, reinserted cart. realigned again-still same message.I need to know if this is fixable,I love this scanner/copier and HATE the 4100 I've got and want my old one back,Is there any help??
  • 62 Answers
Probable, but remember, the things we love we also have to depart with.
try a service centre to see if it is worth the money.
Posted on Jan 04, 2008
Why after installing new ink cartridges, the system says to realign scanner. never saw this before.
Realignment procedure is typical when replacing ink cartridges. It is a pretty straight-forward process and takes only a few moments. Most printers provided detailed instructions on the alignment page it prints - otherwise Google your printer for instructions. Alignment ensures that there are no gaps or white lines in text or images.
Jul 14, 2015 | Epson Artisan 810 AllInOne InkJet Printer
Replacing ink on an epsom wf7010 with generic ink
Try Genuine Epson cartridges and if the white strips disappear then you know it's the generic carts. If not then clean the printer heads, if that doesn't do it then get a new printer.
Feb 10, 2014 | Epson Office Equipment & Supplies
My Lexmark 5600 series will not align properly. Ink levels are both within operating levels, above 75% Will not print documents. The LCD screen flickers up and down, pixels are all scrambled. I have...
Pull out the cartridges and clean any residual glue on the bottom of them by scratching them with your fingernail. Wipe the contacts in the printer and the cartridge with a LINT FREE cloth. Gently replace the cartridges. If they don't go in easily then you're doing it wrong. Clean and realign the cartridges. If these steps don't work then the only thing you can do is hit the cancel (red x) button on the printer to bypass the message for every print job you do.
May 31, 2011 | Office Equipment & Supplies
Toner cartiridges are full but pages are printing blank
Turn your printer off. Disconnect from your computer by disconnection of cable, from the back of the printer. Unplug your printer from the wall.
Remove your print cartridges and gently wipe off the connections (copper or brass colored) with a dry lint-free cloth. Check to see if the bottom of the ink gates (holes where ink comes out) are clogged. Wipe gently with an almost dry but damp cloth, once or twice. Ink will continually come out, so only do this once or twice.
Plug printer back into the wall, connect power cable to printer. Turn printer on.
HP Photosmart will run through a series of checklists. First, it will ask if you would like to "realign" the printer heads. Press "enter" or "yes" and allow heads to realign. If you always have your printer and computer on, this realignment never happens, therefore the heads where the ink is dispersed from the modules will get clogged, and ink will never come out.
Nov 15, 2010 | HP Photosmart C6280 Printer
HP 7140xi comes up with alignment failed after replacing black pr
you could try by passing the alignment
Press and hold Setup and then press OK simultaneously when align message is prompted on the All-in-One.
Jan 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Constant mesage to realign ink cartridges. have done it 3 times and message still there . Cant use copier or scanner facility as a result
Replace the cart. if that does nto work you got a bad print head as its not reading correctly if the cart is aligned witch will send a bad signal to the PCM printer control module to align the cart. please try a replacement if that does nto work replace the print head at that point.
thanks and please do leave postive feedback for your free aolution today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | HP PSC 2210 All-In-One InkJet Printer
Officejet J5780 Every time I turn printer on I get error reading to align cartridge. Tried several cart. and get same reading
One "reset the printer" solution says:
1. unplug power cord
2. wait 30 seconds
3. hold down "#" key AND "6" key, plug in power cord and turn on
this theoretically should clear it. i had a similar problem with an HP 6100 multifunction, and the "reset" steps with that were similar (different keys) and worked.
Jul 18, 2009 | HP Officejet J5780 All-In-One InkJet...
Horizontal Color alignment will not align
Green color means that there is contanimation from the blue and yellow inks. Try to look inside the printer to where the printhead rests when not in use and see if there is alot of ink there. There may be green ink on the sponge there that may be attaching itself to the bottom of the printhead.
Hope this helps!
Feb 22, 2008 | Epson Stylus C84 InkJet Printer
Printer issue
I can only suggest that you should use genuine HP ink carts. Try all new carts and realign again. Hopefully it is under warranty. HP is good at exchanging.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
52 people viewed this question
k24674
Marvin
Marvin
