Question about RCA HD52W56 52" Rear Projection HDTV
TV turning off
RCA 52" HDTV. May run for days, or you may turn it on, and it will blink a couple of times, then eventually turn itself off. There is no set pattern as to this happening. Sometimes when it blinks, the screen appears like the tv is trying to cut off, but it blinks at least 2 or three times, before it finally turns off. I have to wait at least 30 seconds before it will let me turn it back on.
    Genius:
  • 1,030 Answers
INtermitant problems as the are called usally mean bad solder connections...the joints between electronic components. this set when it has a problem shuts down. This is safty cuircits. It could be a connector. when the set shuts down. it locks out for a period of time.. DO you have to uplug it to reset it? IS there any sounds. Without know more i would guess its high voltage.
Posted on Dec 07, 2007
TV not turning on.
Thats usually caused by the small signal board. You can get replacement boards from www.tvrepairworld.com
May 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
When we turn on the tv, it blinks 3 times and turns off
the blinking is a signal to a repair technician which circuit or transistor needs to be replaced but the tv itself will require a technician or replacement
Robb
Apr 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52"rca hdtv lights blink will not turn on
Thats the classic sign of the CP150, CP120 and CP114 capacitors having failed. By trying to power it up over and over the caps will eventually charge and the set will function untill you power it down. You can get the CP150, CP120 and the CP114 repair kit at www.tvrepairworld.com and the kit contains the CD with repair instructions.
Dec 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Will not power on and stay on
Problem is with the IC.Picture tube is OK.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 in tv
ON Deflection board there is 3 capacitors that most of the time will cause set not to startup cp150-cp114-cp120. values 2200uf 16v, two 220uf 35v, you buy caps at Radio Shack.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
