Question about Cannon Canon i960 Photo Printer
Cannon copier pc940 paper jam
Cant get paper jam light to go off - cant find any paper jammed.
  • 4 more comments
  • skitter Dec 27, 2007
    how do we get into the printer
  • lindharma Jan 01, 2008
    canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
  • sislloyd Aug 20, 2008
    There doesn't appear to be a paper jam, but the light won't go off and it won't function. We have tried to clear out the machine, clean it with air to maybe clean off the sensor.
  • Anonymous Mar 25, 2014
    DSM415 was working fine. Copier was moved from one office to another. Paper now keeps on jamming.
  • Anonymous Mar 29, 2014
    printer says paper jam but i cant find any paper thats jammed
  • Anonymous Mar 31, 2014
    The copierer doesn't work at all. The paper was jammed
Canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridgecannon copier pc940 paper jam - 1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Posted on Jan 05, 2008
Small photo paper jammed inside I cant even see it with the front open ....
If you provide the model number of the Cannon printer we can help you get that piece out.
Jan 31, 2016 | Cannon Office Equipment & Supplies
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Cannon mx452 the error light wont go off
try to check if the is a pieace of paper remain the machine or check the seasor where you had to remove the paper
Oct 15, 2014 | Cannon Office Equipment & Supplies
CANNON PC745 SAYS PAPER JAM. NO PAPER JAMMED.
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Brighton2m
Apr 16, 2010 | Canon Office Equipment & Supplies
Cannon MP370, says clear paper jam, none seen
i know that happens to me check that everything it as it sould and resated
Dec 29, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
Cannon Canon i960 Photo Printer Logo
1,098 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Victorman
Victorman
Dennis Gutowski
Dennis Gutowski
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
