Computers & Internet Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW THICK A PAPER WILL THE C6180 PRINT 140
HOW THICK A PAPER WILL THE C6180 PRINT 140 COVER, 100 BOND 335 GSM
James Colynuck
Level 2:
  • Expert 40 Answers
  • Posted on Aug 31, 2009
 James Colynuck
Expert
Level 2:
Answers
40
Questions
0
Helped
38614
Points
153
Use only Genuine HP paper. The packaging will state what printers it is compatible with such as the C6180
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
1helpful
It prints ghost images of the print job
Problem is most likely in the fuser. Are you using thick paper or anything other than 20lb bond.
If so use the printer properties to change the paper type. This will tell the fuser what temperature to use when fusing the image to the paper.
Can A3 300gsm paper be used for a double-sided print run on this machine
Canon IR C3200 Published Specifications:
Acceptable Paper Weights
Cassettes: 17 lb. Bond to 110 lb. Index
(64gsm - 209gsm) and Transparency
Stack Bypass: 17 lb. Bond to 140 lb. Index
(64gsm - 253gsm) and Transparency
2helpful
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
1helpful
My printer is flaking. i am printing a heavy color image on a kyocera fs c8026n. any help?
If by "flaking" you mean that the print is rubbing or flaking off then there are 2 possibilities. If you are using thicker than standard 20lb bond paper then when setting up the print job make sure you are selecting thick paper on your paper setting. This is a common problem if your paper is thicker, shiny or anything other than standard.
The other possibility would be a fuser defect of some type. But that would tend to affect standard black and white prints as well.
Try the thick paper setting as it will slow down the paper speed thru the fuser and will "fix" the toner to the paper better.
1helpful
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
4helpful
2answers
Konica Minolta Magicolor 2530DL
Open the top cover of the printer and remove the drum (piece with long green handle). Look down inside the printer and you will see a roller with ridges. Clean that roller with formula 409. Try not to use alcohol because it dries the roller.
If you are printing on paper thicker than 23lb. bond, you want to make sure you select "thick stock" for the media type on your computer.
For instance... in your application click on file and then print. In the print window select properties (usually). On the setup tab of the next window you will see media type on the right side. Set it to the type of paper you are printing on. This should make the printer pick up the paper slower.
If the paper is thicker than 90lb index (160 g/m2) it is too thick to go through the machine.
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
