AR-M237 iam trying to set up my scanner so that i can save my email address in it. When i scan something iam able to put my email address in it....but iam not able to save it for next time. thanks tricia
  • 135 Answers
Try webbing into the machine if it is networked (ip address of scanner/printer into browser) it should allow you to enter settings and save
Posted on Aug 05, 2009
I got an error code L3-00 on my Sharp AR-M237 can help you. dalmircfranck@hotmail.com
The L3-00 means that the scanner is not in home position. You can try turning off the machine and unplug it for a minute or so and then turn it on. If that doesn't work you can take off the glass and cleaning the rails the the scanner slides on and then put a slight and I mean slight layer of lubrication on the rails like ATF.
Oct 15, 2011 | Sharp AR-M237 Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
AR-M237 PRINTS BUT DOES NOT SCAN
You may have a problem with the physical board connected to the machine, try re seating the card with the machine off and unplugged. Its a data issue over the network, it may be the board itself. Try re seating it first.
Mar 23, 2010 | Sharp AR-M237 Copier
Code: E7-10 on Sharp AR-M237
Your lsu or laser scanning unit is deffective that's why E7-10 appears. it should be replaced
Mar 11, 2009 | Sharp AR-M205 Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Scanner
If you go to copiers web page you will find address book in that, to axcess web page type in copiers ip address in web browser (explorer) , you can find copiers ip address by printing out config/setting page of copier or looking at print driver port setting on pc, a IP address look like this 123.123.001.023
Oct 29, 2007 | Sharp AR-M277 All-In-One Printer
257 people viewed this question
k24674
jasbo
jasbo
