Question about Pioneer SX-205 Receiver
Pioneer SX-203 Receiver powers up but no sound from any speaker outputs.
  • jay1000 Dec 16, 2007
    receiver turns on but no sound from outputs to speakers
  • Eliezer Pennywhistler
    Eliezer Pennywhistler May 28, 2013
    If it is like mine, play around with the two speaker selector switches. On mine, no sound comes out if I push in SPEAKER A, but it works OK if I push in SPEAKER B and make sure A is off.
Check the 2nd Tape monitor switch. If on it kills signal path.
Posted on Jul 19, 2012
A little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Posted on Aug 07, 2008
My pioneer sx 203 plows the fuse as soon as you hit the power button
Posted on May 22, 2011
Try taking the receiver apart and checking the fuses.
Posted on Mar 23, 2008
    There is one fuse. If it was blown the receiver wouldn't power up, would it.
My pioneer sx 203 stopped working. It no longer powers up. It was playing fine then I turned the volume up from 3 to 5 and it totally shut down. Doesn't work at all now.
If it shuts down after turning up you have a speaker and or speaker wire issue, Try disconnectiong all speakers and see if it shuts down then, If it shuts down with no speakers connected then you do have a receiver problem
Feb 18, 2015 | Pioneer Audio Players & Recorders
My Pioneer SX 315 receiver powers on but then shuts off right away
Sounds like there's either a serious problem with the speaker wiring, or the wiring problem has escalated in to a blown output transistor
Sep 04, 2014 | Audio Players & Recorders
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
Pioneer Receiver SX-205 flashing ''overload''? Nothing in owner's manual troubleshooting chart.
usually it is a technical indication of the output being shorted. disconnect all speaker wires and try again. still blinking?
Mar 06, 2010 | Pioneer SX-205 Receiver
I have a Pioneer Audio Multi Channel Receiver model SX-316-S and I can't seem to figure out how to hook up my TV and DVD to the receiver so that all sound comes through the receiver
DVD audio straight in from its highest quality audio output. Use the stereo audio output to run straight to the TV for casual watching through TV speakers without the Pioneer involved.
A TV is just a glorified night-light, not a sound source - get its related audio from the Cable Box, ditto the highest quality
Mar 04, 2010 | Pioneer SX-315
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
No sound from speakers?
This is likely to be th output relay having corroded contacts. The headphone output is taken directly from the sepaker output but fed through resistors. The output relay has failed.
Dan
Mar 09, 2009 | Pioneer Audio Players & Recorders
Pioneer SX-205 Receiver Logo
1,802 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
