Question about Konica Minolta magicolor 2300DL Laser Printer
Fatal error 17H
I took out each toner, replaced, and still getting fatal error, ???what to do next?
  • C-los135lidi Jun 05, 2008
    I get a fatal error message and the black toner is stocked, can't rotate; what can I do to get this drum out?
  • 3 Answers
Try going through each toner cartridge again. The error is linked to incorrect rotation usually caused by badly seated toner cartridges.
Chris
Posted on Dec 27, 2007
Fatal Error 17H
Hi
Thanks for using FixYa. Error 17H means rack rotation failure. While replacing toners, one of them might not be sitting right and due to this cause, the cartridge is stalling the rotation of the rack. You need to remove all of the toners installed by selecting the properties of the printer. After that select "install toner" and reinstall all of them. Check for any physical damage on anything around the toner rack or a small piece of paper jammed in the right hand side of the toner rack.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jul 23, 2009 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17h
17H is the Rack Rotation error. If your toners are not rotating correctly, or if you have the wrong type (IE 2400 series toners in a 2500 series printer) you will get this error.
Feb 18, 2009 | Konica Minolta Magicolor 2530 DL Laser...
FATAL ERROR
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
Service Call 17H This pops up when I try to print multiple pages.
FATAL ERROR
CODE: 17H
SERVICE CALL 17
TONER RACK • If the toner cartridge does not rotate
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Step Remedy Reference
page
WARNING DIAGRAM
Control signal Location(electrical component)
1 Check PC4 operation. 149 PC4_ON 3-F
2 Check CL1 operation. 150 CL1_REM 2-F
3 Check M2 operation. 151 - 3-E
4 Replace PWB-A. - - -
hope this helps
Jan 09, 2009 | Office Equipment & Supplies
Where are the toner cartridges in magicolor 2300 dl
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Rack motor (M2)
Rack clutch (CL1)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal Error 17H - toner cartridges will not advance
Open the front door and remove the toner bottle.
Look near the colour toner carts and you will see a small round hole. Jam a screwdriver in that hole and the carousel will rotate freely. Move the carousel round and remove each toner one at a time.
Oct 10, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
678 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
