Question about Philips 32PT6441/37 32" TV
Phillips 32 Can I hook up my computer usb port running my desktop monitor to the usb port on my t v and use the television screen for a monitor?
No. USB doesn't send any images. Its a data line.
That said, I can't see that your TV does have a USB port.
However, the TV does have s-video in which COULD be used to show your PC on the TV. However, it won't look very good. (Certainly not as good as a computer monitor).
Posted on Dec 06, 2007
I have a toshiba laptop with bad screen.I would like hook up external monitor as a primary monitor
Laptops dating back some 10yrs ago had VGA ports on them. Unless your Toshiba is a dinosaur, it should also contain the VGA port. From this port, you could hook up an external desktop style monitor and still use your laptop.
Aug 27, 2011 | ASUS Computers & Internet
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
I am trying to hook up my computer to my lc321ss9 b tv. I hooked it up to the VGA port and it says format not supported?
your screen resolution probably exceeds that of the tv.
try playing with your screen resolution.
May 02, 2011 | Sylvania LC-321SS9 32 in. LCD TV
Hooking up to mu computer the monitor states no signal
Is the monitor set to the correct input source? Is the cable fully seated on both the computer and the monitor? Try a new cable. Is the computer sending the video signal to that port that has the cable? Laptops sometimes need the external video port enabled in the BIOS, for example. Check your manual to access the BIOS; frequently it is F1, F2 or ESC pressed before the OS starts to load. Some newer desktop computers do not have the VGA port enabled initially as well.
I hope this helps.
(on my Win7 desktop and laptop, to turn on a second monitor it is under Screen Resolution (shortcut from the desktop by right-clicking anywhere there isn't an icon or running program).)
Jul 17, 2010 | Mag Innovision LT776s 17" LCD Monitor
No Sync message on the TV screen
Is the VGA port enabled? Have you set the computer to send data to the port? (The first may be part of the BIOS or the Device Manager. The second is in the graphics properties - right click on the desktop.) Reboot the computer to make sure it sees the new hardware with the monitor/TV on. Is the cable good? Try another one.
I hope this helps.
May 28, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
The monitor has 2 USB ports on the left side of
It is basically 2-port USB powered HUB built into the monitor, did you hook up the USB cable from the monitor USB Input port to the USB port on the PC?
Jan 08, 2010 | HP w2207 Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
I just received a (refurbished) Pavilion Elite m9350f. During setup, I attempted to connect my old VGA monitor. It would only be recognized by using the adapter for the one DVI port. When it was hooked up...
plug monitor into VGA port, start machine, go into the bios settings and load optimised defaults press F10 then reboot, if the problem persists its your graphics card or monitor
Nov 13, 2008 | Computers & Internet
Philips 32PT6441/37 32" TV Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
