Question about Cobra HH 38 WX 40-Channels Handheld CB Radio
Cobra 38wxst was droped in water
i dropped my radio into water.i want to take it apart to clean a dry it out.i removed four screws that i see but it will not come apart.
help,
moses brown
    Novelist:
    Champion:
  • 211 Answers
The inner screws also need to be removed after you get the back panel off. Also, the antenna is connected with a nut to the case, and the antenna has a wire soldered to the board. They are kid of a trick to get into, but not impossible. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
How to disassemble and reassemble
Hi
I believe this is one of those cases if you have to ask, then you likely shouldn't be taking the radio apart as there are no user serviceable parts inside. Having said that, there are usually four phillips screws holding the radio together.
Think looooooong and hard before you decide to disassemble it.
Mar 04, 2015 | Cobra Radio Communications
I left the batteries in it, and one of the batteries corroded. how can i take it apart to clean it
One old trick was to use some baking soda on terminals. It will turn terminal black, but you can still use it if terminal is not broken off. If you have soldered in batteries clean an scrape terminal an resolder.
Feb 22, 2014 | Cobra HH-38WXST CB RADIO 40CH 10 WEATHER...
Are there any modification to increase reception and Modulation for cobra 38wxst?
the person is talking about a cobra 38wxst and you guys give him information on a cobra 25,but the information is solid as to what is said Check your SWR ,Make sure your squelch is open,check for dust on the knobs , and then take it to a tech and let him fix it because a receive alignment is more sensitive then a tx alignment.
Sep 21, 2013 | Cobra 29 LTD CB Radio
How to increase modulation on cobra 38wxst
VR-4 is the modulation pot. turn it all the way to the left. If no one can hear you then turn it all the to the right .
Feb 28, 2013 | Cobra 38WXST Handheld CB Radio
DO YOU HAVE TO SET THE SWR`S ON THE COBRA ROADTRIP RADIO
only if you hook it up to an external antenna like the one for a mobile unit on your car.
Feb 21, 2013 | Cobra Roadtrip Hh-38wxst Handheld 40...
Cobra handheld cb radio stops working when inserting external power source
If it works with batteries but no via the external input for power either the socket for that is bad or the source voltage is not there when connected that way
Dec 04, 2012 | Cobra HH-38WXST CB RADIO 40CH 10 WEATHER...
When docking the headset cobra road trip and activate the ptt who hear me get a ring
  • Hi, I can help. When the microphone/earphone set is inserted in the radio itself the control is automatically turned over to the headset. There are no radio adjustment that need to be done. Just plug it in and use the PTT on the cord of the headset or unplug and use the controls on the radio itself.
  • Many don't know that the Cobra Road Trip and the Cobra HH 38WXST are identical radios. The only difference is the antenna sold with the two radios. The one you have come with a rubber duck style antenna and the HH38 WXST comes with a magnetic car mount antenna. So while the manualfor the Road Trip is hard to find the 38 WXST is not. Here is a copy of the manual http://minus.com/mTQOgU0yw
  • Read through the manual a couple times and feel free to get back to me with any questions you have.
  • Hope this helps.
Oct 28, 2011 | Cobra Road Trip 40-Channels Handheld CB...
Dropped phone in water for about 2 sec and pulled it apart right way and let it dry, can it be fixed
problem can be solved.When a phone drops into water the water stays inside the phone.When the water dries insid the board of the phone, it might bridge two IC together and cause demage or makes the phone to act in a strange way.
In order to remove the water from the phone the phone needs to be serviced for it to work properly.
Get a screw driver that can loosen the screws on the phone, unscrew and remove the board of the phone, get a methylated spirit and a brush to clean the board in other to remove the water inside the phone.
After brushing the board, leave it to dry for 10 minutes and fix it back into the phone and the phone will be back to live.
NOTE: if you can lose the phone , i would advice you take it to a mobile engineer to fix it for you in other to cause further damage to the phone.
Have a nice day.
Mar 16, 2010 | Motorola Mobility CLIQ Cell Phone
Cobra HH 38 WX 40-Channels Handheld CB Radio Logo
288 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
