Hotpoint 24 in. HDA3400G Built-in Dishwasher
Problem for Hotpoint 24 in. HDA3400G Built-in Dishwasher
Won't drain
By wghbgh on Aug 31, 2009
I have lost the manual. The unit won't drain water out in regular cycle.I have removed the drain cover and have gotten to the spin arm but where do I go from there?
Best Solution
posted on Aug 31, 2009
Very Helpful)
justaskjoe
Rank: Guru
Rating: 85%, 2036 votes
hello. i can help you. remove the lower panel and in there you will see the drain hose going from a little pump near the floor upwards and ultimately connected to your plumbing under the sink. Disconnect it at both ends and examine it for a blockage. Also, remove the little pump and look in it for a chunk of glass or something else that partially blocks it. finally check out the sink trap and or the garbage disposal [if u use one] still looking for a blocked pipe.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" I saw a lot of people had the same or higher end model but all had the same problem. And yep, it was at the drain screen where they said. Thanks! " - wghbgh
Popular Solutions for Hotpoint 24 in. HDA3400G
Questions and Unsolved Problems for Hotpoint 24 in. HDA3400G
Do you recommend Hotpoint 24 in. HDA3400G Built-in Dishwasher?
Answer
Answer
clip broken off detergent loader container, container will not clip shut.
Answer
how do i drain the macerator connected to my toilet, it has broken and needs to be changed. this... (More)
Answer
the solenoid for the waist water dump valve has over heated and melted twice. valve not the problem.... (More)
Answer
My dishwasher does not drain. I've pulled off the main top screen. What next? How do I pull off the... (More)
Answer
Machine went through first light wash and then stops on the second light(spray) and beeps and won't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA3400G...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
