Question about Star Logic 17" LCD Monitor
BLANK MONITOR My 17" Starlogic monitor remains black/blank. The green power button is flashing (not quick, but flashing) and I can hear a clicking. Help / I can not get the monitor to show. I have rebooted. Any Idea's?
  • 2 more comments
  • Skippy04 Dec 06, 2007
  • fgs2 Dec 30, 2007
    same problem sometimes i can turn computer off unplug both cpu & montitor turn monitor on till get no signal showing hook up monitor and then cpu plug turn on computer and after afew times this works but then i have to use my XP disk to boot up monitor and voard work traded them out to check and they work just fine till i put them back in my new computer this couldn't be due to a motherboard change i just got a asus a7v333-x motherboard someone gave me to reeplace the one that went through katrina i had no disk for it for p4 its slow and pauses alot just can't get it right asus not beeing alot of help this time the cpu was turned off and its bee three days and i cant find the right combo to get it back on when i justrestart every thing seems to work monitor comes on up and dont need to boot with xp disk excepet now i need this thing for work katrina has sure put a hurting on my work wife is an artist and i print stationary and trying to get us back online so any help greatly needed and thankfull
  • boboie May 18, 2008
    my monitor stayblack but when i hit the green on boyyom my montior flashes but doesn't stay on can you help me sharon
  • dcloftin Mar 02, 2009
    monitor is blank with green blinking power light but will not start up
  • 85 Answers
The signal stage of your monitor is likely to have a problem, if the cpu is working fine then troubleshoot the signal stage of your monitor or visit a local technician
Posted on Apr 22, 2008
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck
Jul 24, 2008 | Star Logic 17" LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
255 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
