SOURCE: where is fuse box located on 2001 lincoln ls...
You have fuses and relays-
Under the hood.pass side,front,next to washer bottle and ABS motor
On the right side kick panel,under glove box. Have to remove cover
In trunk,lift cover,left of battery.
SOURCE: Location: Coolant Temp Sensor 2001 Lincoln LS V6
It is on the Driver side of engine in between the COP's (Coil on plugs) simply unplug the wire use a 19 or 3/4 deep well socket and unscrew it and put it new one... The whole process should only take 10-15 minutes.
