Question about KitchenAid KSRD22FKBT / KSRD22FKWH / KSRD22FKBL Side by Side Refrigerator
Refrigerator and freezer stopped working
I have a Kenmore side by side refrigerator/freezer. Both stopped working at
same time. My husband took back off and said it was full of dust since,
he had not performed the cleaning in some time. I notice the floor was
sticky and had a slight orange/red tone on it in two different areas about
8 inches apart. Do you have any idea of what the problem is. I need an answer like yesterday.
  • 1462 Answers
SOURCE: Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Posted on Jul 13, 2007
SOURCE: refrigerator stopped cooling
I too have a Kenmore, Model 106.52209100. No cooling at all in freezer and refrigeration sections. Lights and control panel status lights working. Motor running but only warm air. Issue was a relay that needed replacement. $71 for the relay, $180 fo the repairman.
Posted on Mar 05, 2008
SOURCE: Refrigerator stopped cooling
I have the same problem on my GE model :
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
Posted on May 26, 2008
SOURCE: water leaking inside of refrigerator from freezer
I have a side by side kitchen aide Model # KSRA25FKBL00. The freezer was leaking, we keep finding water on the floor and when you opened the freezer the floor of the freezer was covered with ice. I tried finding a solution online but they all seemed to involve removing parts and I wasn’t conformable doing that. I just had a repair man here.
I spent $125 to have it fixed. It took him less than 5 mins. What he did was chipped the ice away. He took a plastic bottle with a small plastic hose coming out of it, filled with hot water and poured it down the defrost drain at the bottom of the freezer. I don’t think you really would need the tube. There is a defrost drain at the bottom of my freezer that drains into a pan under the fridge. The repair man said it defrosts every 8 hours and drains and sometimes it gets clogged.
I hope someone can save some money with this tip; it was such an easy fix. He tried to block what he was doing, but I stood over his shoulder watching.
Posted on Dec 27, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
Posted on Feb 17, 2009
Kenmore elite trio 596 73503201
This happened on my side-by-side. There is a damper at the inside top of the refrigerator compartment that was failing to open to allow cold air in. I took the cover off and propped open the damper while I ordered the part and waited for it to arrive. Problem solved and hope to keep it running another few years.
Nov 13, 2013 | Kenmore Refrigerators
Freezer door is leaking water at the bottom of the door
This sounds like the defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle.
If you can see ice on the bottom of the freezer floor, then this is likely your problem unless your ice maker is leaking from the top of the freezer.
Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Kenmore fridge/freezer side by side isn't staying cold
Ok so we just had our Kenmore fridge quit cooling , everything in the freezer defrosted , and we lost a lot of food,BUT my husband ordered a part #8201786 which is a starter , and installed it and it worked! The fridge was clicking but it just wouldnt kick on, and the fan still worked. There are websites that you can order the part from, It cost $63.05 with tax!!!! good luck
Mar 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator isn't working anymore
Try to completely defrost it, then if the freezer works but not the fridge change the thermostat
May 31, 2008 | Kenmore Refrigerators
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
Sep 26, 2007 | Refrigerators
KitchenAid KSRD22FKBT / KSRD22FKWH / KSRD22FKBL Side by Side Refrigerator Logo
32 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
