Question about Toshiba 32AF43 32" TV
Distorted television image
Good Morning,
My Toshiba 32 inch television image is pulled in on the sides about two inches. Any info on what may cause this and any remedies?
Brian
    Sergeant:
    Champion:
  • 375 Answers
Bad caps in power supply and poss. pincushion section.
Posted on Mar 28, 2008
Toshiba 32 inch have double image
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 09, 2016 | Toshiba Televison & Video
Distorted Image smart vizio tv 32 inch
It sounds that the T'Con board has failed. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 30, 2013 | Vizio E322ar
32 inch sony bravia EX400 showing distorted colors and red screen on start up
reconnect the cable that goes from main board to tcon.. if this dose not work out change the tcon board which is cheap arond 25 US dollors..
Mar 29, 2012 | Sony Televison & Video
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
Cat knocked over the Dynex dx-lcd32 TV and dented the screen in.
To answer your question, your probably better off buying a new television. LCD tv's are made of a thin layer of special ionic chemicals sandwiched between two plastic plates, this allows it to light up to produce an image. If your television image is distorted in any way, this means the ionic chemicals have leaked or become solidified, any repair (if even possible) would require replacing the majority of the television, and it will be cheaper just to get a new tv. Sorry Ron!
Mar 04, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
Jan 29, 2009 | Toshiba 50HDX82 50" Rear Projection...
No Color image - B&W image is distorted
it could actually be the cable box itself or there could be corossion on the cable connection outside
Dec 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toshiba 32 inch tv picture is distorted
have you tried pic size on the remote to adjust the image. normal is the factor default.
Jan 29, 2008 | Toshiba 32AF43 32" TV
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Toshiba 32AF43 32" TV Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
