SOURCE: wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
