Question about Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor
Help with a system shut down?
I have windows xp on a pentium 3. and i turn it on its ok for like 3 or 4 minutes then i have the system shut down count down where i have like a minute left and it shuts off why does it do that.
  • 310 Answers
Hi, does it let you get into windows then give you a 60sec countdown if it does, its a virus. its kinda easy to fix this one,
Once its into windows click start button, click run then type
shutdown -a (press enter)
this should stop the countdown
you need to download or install a new virus checker,
this one is good and lasts 30days free,
Remove viruses and should work fine..
Have a good christmas
Ps you will have to do the run, shutdown -a everytime the countdown appears until the virus is removed...
Posted on Dec 13, 2007
I have a IBM Think pad laptop running Windows xp that keep shutting down, it go through the POST OK. then 2-3 minutes it shut down. The fan is OK, and the cooling system is ok, so what do I do next.
its either a software problem or a hardware problem
normally over heating shuts down older style laptops
try using a lap top cooling pad
sometimes its a faulty hard drive
Try reinstalling XP windows again
May 21, 2015 | IBM Computers & Internet
Dell code 2000-0148
It could be the motherboard, but it is more likely to be a hard drive. Back up anything you need as soon as possible and replace the drive and re-install the operating system(Windows)
Jul 28, 2013 | Dell Latitude D630 Intel Core 2 Duo T7250...
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
Windows cannot find regsvr.exe at start up
Probably the easiest way to resolve this issue is by following the steps outlined below.
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
Jul 31, 2010 | Microsoft Windows XP Professional
Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
Dec 01, 2009 | Microsoft Windows XP Professional With...
I need to unlock the image on my computer, it was locked to protect my files. Windows simply does not show up on the screen not the start button? I am unable to start my computer! Windows XP, Compaq,...
Try to reset your in bios by entering setup in the startup. All you have to do is to press del or F2 botton some computer use F12 to inter bios setting.Or to remove your battery from the motherboard.
Nov 18, 2009 | Microsoft Windows XP Home Edition
When i try to play the game i get fatal error msg
Devil May Cry 4
Minimum System Requirements
OS: Windows XP/Vista
  • Processor: Pentium 4 @ 3 GHz
Memory: 512 MB (1 GB for Vista)
Hard Drive: 8 GB Free
  • Video Memory: 256 MB (nVidia GeForce 6600 SM3 Required)
Sound Card: DirectX Compatible
DirectX: 9.0c
Keyboard & Mouse
DVD Rom Drive
Recommended System Requirements
Processor: Intel Core 2 DUO
Memory: 1 GB (2 GB for Vista)
Video Memory: 512 MB (nVidia GeForce 8600)
DirectX: 9.0c or 10
Keyboard & Mouse
DVD Rom Drive
Seems like your graphic card is not supported. Its a older version. My first solution would be update your driver for your graphics card: or
If that doesn't fix it (which I don't think it will), you might just have to buy yourself a better graphics card and/or computer.
May 30, 2009 | Capcom Devil May Cry 4
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
Jan 16, 2008 | Computers & Internet
Petium 3 processor with windows xp
Just a bit of information. Your slow speed reguards to DSL is bull. Unless your ISP requires your system to run a min Mhz cpu. Cant really suggest how high you can up your cpu unless we know the model of the board & it wouldn't hurt to know the bios version too. Here is a small list from Fixya of Dells & Pent III.
Jan 05, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
