Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Red light lit on front panel indicating a bad lamp
The red light is lit on the front panel.I replaced the lamp but the red light is still lit.
I suspect a power supply( capacitor) problem. where is the location of the power supply board?
Thank You
  • 2 more comments
  • Neal Coticelli Dec 07, 2007
    I figured that the power supply board would be close to where the power cord is.
    I have the back off the set but how do I get at the power supply board?
    It cant be too difficult. According to the posts others have done it.
    Techman may know the answer to this.
    I need to know how to get at the power supply.
    I have the back panel and the rear plate off.
    I can see where the power cord goes but how do I disassemble whats in front of it?
    According to the posts others have done this but they dont say how they got at the power board.
    If I can get the power supply board out I can check the caps.
    Techman has the answer,he answered most of the similiar posts.
  • Neal Coticelli Dec 09, 2007
    I know I should check the power supply and I know where it is, I just dont know what to take apart to get at it.
    Im assuming here that the lamp is bad so I would like to check the power supply and dm boards before I invest in a lamp which may not work.
    I have the service manual but it does not show what to take apart to get at the boards.
  • Neal Coticelli Dec 10, 2007
    I would still like to know what I have to take apart to gwt at the power supply/dm module.
    If I can get at the supply I can check the caps.
  • 1,153 Answers
First check F9A06 this blows at times. If not the problem you anc do This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Posted on Dec 10, 2007
  • 456 Answers
Check out the whole power supply wire and also your plug then goin it it may guided by the power supply wire
Posted on Dec 09, 2007
  • 133 Answers
It'll likely be right behind where the power cord from the TV comes from.
Posted on Dec 07, 2007
I changed the lamp on my pt44-lcx65 panasonic tv and everything comes on great but red lamp light is still lit
Turn on the television.
  1. Press the volume down button on the TV display (not the remote!)
  2. While pressing the volume button, press the "split" or "PIP" button on your remote.
If it works, you'll see a message like this, an the lamp indicator light will turn off. Success!
May 30, 2014 | Panasonic PT-44LCX65 Television
Tv is turn on and red indicator is steady lit then after a minute the tv is turn off and red light is lit steady why,
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 08, 2014 | Panasonic 2 Projector Lamp
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
hello Gabriel
Could you check your SyncMaster 2233 for me and tell me your findings. If this monitor is connected from your computer and when both switch on, did the led indication lamp from your monitor lit steady green? or this lead indication lamp lit green then turns red?
1. If the led indication lamp lit steady green then there is nothing wrong with the settings, configurations, driver or hardware on your computer. The problem would be the backlight inverter lamp in your monitor is busted. Or it could be the inverter board that supplies high voltage for the backlight inverter lamp that is bad. You can replace the backlight inverter lamp located at the upper and lower part of the monitor with a replacement part you can purchase at Inverter board repair can be risky if you don't have the skill. Even opening the back cover of your monitor and replace by yourself the inverter lamp is risky too, could inflict more damage. you can bring it to a local professional service man.
2. If the led indication lamp lit green then turns red, then if not the video card the power supply section from your monitor is bad, you can replace polarized capacitor with same value. Just inspect and those with blown or leaking capacitor. You can also check the terminals and solder joints for the 15-pin vga terminal connector where vga cable is connected on your monitor. Resolder the terminals.
3. If the red indication lamp did not lit at all. Power supply section in the monitor is bad. You can check the output voltage from the power supply section. +5VDC is supplied for the main board and +24VDC is for the inverter board. Replace leaking or blown capacitor with same value.
Just remember, this should be done when computer and monitor is turn off
Post back if you have more questions. I am willing to give you assistance.
Feb 10, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
How can i tell if the lamp is bad. The t.v tries to come on but it never comes on. A red light flashes next to the bulb sign on the front panel
The indicator light next to "lamp" flashes when the projection lamp needs to be replaced, take a quick look at your operators manuals "troubleshooting" section for help on what these "warning lights" on the TV mean.
Good Luck !
Apr 19, 2010 | LG 52SX4D 52" HDTV
EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
I just replaced the lamp on my sony wega 42WE655 tv and the lamp replacement indicator light onthe front no longer indicates that it is bad, but the standby light keeps flashing red. when i try to turn it...
If you just replaced the lamp then there's something wrong in the power circuit or you have a bad lamp. If you can I would take the back cover off and look at the board where the power cord connects and lok around it for swollen capacitors. Let me know if you find anything.
Oct 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV turns off after about a minute flashing red light on lamp indi
your tv is talking to you basically, is telling you that the lamp has to be replaced. this is a common problem with this dlp tvs, when the lamp is bad the shuts off within minutes, so just replace the lamp my friend.
May 26, 2009 | Zenith D60WLCD Television
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link -
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
