Question about Admiral AW22 Top Load Washer
There is a squealling noise
My washer has a squealling noise during the spin cycle. I have replaced the belt and it still is doing it. Thanks Shannon Erwin
  • frontierace Dec 12, 2007
    my machine started to squeel 2 days ago. now it can hardly spin and leaks all off the water out underthe machine
    Problem Solver:
  • 19 Answers
Posted on Jan 30, 2008
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
MAV408DAWK Maytag top load washer is squealling
The noise could be coming from the wornout drum bearings. It needs replacement.
Oct 13, 2009 | Washing Machines
Noise during spin cycle
I Can help
1: Unplug the Washer, turn off hot cold supply to Hoses.
2: Turn Washer around and remove Cover on Back.
3: Look at the "Belt" pull on it to see if it is Loose.
4: Check the "Pulleys" The "Belt" is connected to. Look for Signs of "Blackness" Caused by the Belt Wearing.
5: If thats the case just Replace the Belt.
Hope it helped
Please Rate Me
Apr 28, 2009 | Kenmore 43042 Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Admiral AW22 Top Load Washer Logo
74 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
