Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Brothers intellifax 4100
Keep getting message check cassette #2 reinstall cassette properly. I have no idea even where the cassette is........
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Cassette is in front, put hand on bottom front of machine and pull, check to see if it is set to letter ( is the paper adjuster the part that can slide back and forth set to letter is there a switch in the cassette for custom and letter size? is it set to letter?
Posted on Dec 10, 2007
Where would I get a power cord for a 4100 and also a set of directions?
Posted on Feb 19, 2008
Check cassette #2 reinstall properly
do you have a cassette #2 installed? If not, you can tell the machine in the menu settings that the cassette #2 isn't installed at all.
menu (set)
general settings (set)
Cassette #2 change it to off(set)
Hope this helps.
Dec 29, 2009 | Brother IntelliFax-4100e Fax
Our brother intellifax 4100 does not pick up the paper. Is there a protocol to follow and or a repair kit etc??
make sure paper stopper in cassette is not pressed too tightly against the paper. common problem on these models. best to leave an 1/8" gap.
hth,
razors
Dec 08, 2008 | Brother IntelliFAX 4100 Laser Fax
BROTHER INTELLIFAX 4100
When we set the time on our fax it doesnt save the correct time, we set the time and it only stays for about a couple of days and it changes. Do you have any ideas for a solution.
Heather
Oct 31, 2008 | Brother IntelliFAX 4100 Laser Fax
First plug in a normal tone tellefone into the wall jack that your fax is using.Make sure you get the fax signal from the faxnumbers you struggling with.If you can hear any line noises on the line it may be the problem why you cant get a fax trough.Make sure your fax is set on the correct county code-tone or pulse.
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Paper jam
Check your printer first, restart your pc and then try to print. If the message is paper jam again. Try to reinstall the software, if doest work properly the problem is your printer.
Jun 18, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Mar 03, 2008 | Brother IntelliFAX 4100 Laser Fax
No incoming or outgoing fax
do you have a second cassette installed? If not, you have somehow activated the feature. Go into the menu and deactivate or turn off the second cass. feature. Owner's manual has instructions.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 31, 2007 | Brother IntelliFAX 4100 Laser Fax
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
503 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
