Question about Lexmark X6170 All-In-One InkJet Printer
Scanning Problem I'm finding that when I scan documents, the scanner is eliminating the margins when it scans.  Is there anyway to stop this?  I want the whole document, with margins to be in PDF format.
    Problem Solver:
  • 11 Answers
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Posted on Dec 06, 2007
Is there a way to define scan area settings in CapturePerfect v3 to allow for different margins when scanning front-side and back-side of a paper? I.e. to compensate for differences in left and right...
Interesting question. I don't think there is a solution from CP3. It is logical to assume that front and back sides are of the same size and hence there is no provision in the software. One option is to scan once for say top side(left margin) and change the settings (select reverse scanning, i.e, bottom side only) and alter the margin as required, nevertheless you will have to scan twice. You can also crop after the images are generated separately, but it is difficult to separate odd and even images, assuming there is a large number.
S. Mohan, Chennai, India
Aug 18, 2011 | Canon DR6050C A3 Document Scanner 60PPM
When I'm scanning a document on Canon 7580 each page will show up on my computer screen with a slighly different margin (keeps shifting left to right). The document is being fed into the scanner...
Under CapturePerfect3, you can choose to deskew the scanned image while scanning itself. Also select 'Image only" radio button instead of 'Guide Plate'. The software will remove black borders around the image.
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
How do I scan a document please?!
you can a document using a scanner.
1. you have to find a SCANNER machine that is responsible in scanning the files you want to scan.
2. Then after you find a scanner, next thing to do is to place the document file in the scanner and make sure that your scanner is properly connected and turn on.
3. Click and run the software that is bundled with the scanner to scan the document and then you have to set the path where your scanned file is to be place.
4. Then after the scanning process finished then click the save button to save the scanned files.
Thanks
Sep 15, 2009 | Office Equipment & Supplies
Seperates the pictures from the text when scanning
Stop scanning as an OCR. Scan as a PDF or photo and it will scan it exactly as it was on the scanbed.
When scanning for OCR OPTICAL CHARACTER RECOGNITION it is translating the text for notepad and saving the pictures at the end or in separate files.
Mar 30, 2009 | Microtek ScanMaker i320 Flatbed Scanner
Black line at left margin when scanning any document CX3900
Check to see if the glass part of your scanner is clean. Usually its dirty when you have that problem
Mar 12, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Scanning not picture perfect. In scanning a letter - the symbol on the letterhead did not print correctly nor did the signature part. The left margin also increased by 1 character. Bert
It is possible that teh letterhead is too light that the scanner cannot see it any longer. can you try another document and see if the same problem occurs. If not then adjust the scanning settings.
Sep 16, 2008 | Computers & Internet
Lexmark X6170 All-In-One InkJet Printer Logo
392 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
