Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Cassette You didn't tell me if I can purchase another cassette and if so where can I get it from.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Try this site, i use them to buy parts for my machine,( not an endorsement)
http://www.precisionroller.com/
Posted on Dec 10, 2007
My Epson Artisan 7-110 keeps trying to print to cassette 2 (small cassette) even when copying A4. A4 paper is loaded in Cassette 1. Why?
If its not a setting problem, it may not be communicating with your computer properly, try turning it off, wait a little while and turn it back on, if that doesn't work delete your printer off your computer and re install it, Is it the default printer on your computer? some times if you run more than one printer from your computer there's a conflict which can make it behave in weird and wonderful ways.
Sep 22, 2014 | Epson Artisan 710 AllInOne InkJet Printer
Reset Minolta cs pro 3050 to Factory
Co920 - 1st cassette problem
Co910 - 2nd cassette problem
Co900 - 3rd cassette
Co950 - 4th cassette
Open and close the front after copier is ON,if the message is apper enter in the service mode,or pull out the cassette failure and work.
Service mode enter:press STOP - 0 - STOP - 1
Check the actuators in the cassette,feed rollers and the sensors.
Jan 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
How do you get the gear sprocket off the back tire of a mongoose crossway 450 bicycle
To remove any rear freewheel or cassette you will need to purchase a Park Tool. Park Tool is the best brand when it comes to bike repair. Google Park Tool and you can look through their products. You will need a cassette/freewheel remover. There are dozens of different companies that make hubs and cassettes (gear sprocket). Take a look at yours and see what company made it. You can than find out which tool with properly fit your cassette. These tools are made to fit in a wrench making hand removal easy. Some brands will require a chain whip. The only way you will know which too you need is by find the company name on the cassette/hub. Without this tool removal is virtually impossible. If you need help narrowing down which cassette remover you need you can always let me know the company name and I will let you know the proper cassette tool to purchase.
Oct 31, 2011 | Mongoose Exile 26 Men's Full-Suspension...
Check cassette #2 reinstall properly
do you have a cassette #2 installed? If not, you can tell the machine in the menu settings that the cassette #2 isn't installed at all.
menu (set)
general settings (set)
Cassette #2 change it to off(set)
Hope this helps.
Dec 29, 2009 | Brother IntelliFax-4100e Fax
What tape cassette fits a Panasonic TRC3500?
This recorder takes MINI cassettes, not MICRO cassettes
Aug 09, 2009 | Sanyo TRC-3680 Handheld Cassette Voice...
TRV285 E, Insert cassette msg is appearing
I also had a similar problem. There was a message appearing "re-insert the cassette". I contacted Sony India. They advised to reset the Handycam (there is a button 'Reset' under the LCD when it is closed). After doing the Reset the message disappeared and it is working fine at the moment. I also checked up a forum for the message. A lot of people having the same problem were suggesting to whack the camcorder on the cassette side. Although i did not have to resort to it.
Dec 25, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Brother MFC-9700 error message says "reinstall cassette #2 properly". It is installed properly. Turned machine off. looked inside, no paper jambs, cassette seems to be okay, reinstalled just...
I just experienced the same issue, and from research it looks like there is an optional second paper cassette that you can purchase. If it is set to have the second cassette turned on and you don't have that option the machine is looking for something that does not exist. In my case cassette #2 was turned on via the menu (Menu, Option 1 (General Set-up), Option 5 (Cassette #2), make sure it is set to "off"). Once Cassette #2 was set to off the machine started working properly again.
Jul 10, 2008 | Brother Office Equipment & Supplies
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
37 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
