Question about Rode NT1A Professional Microphone
RODE NT1A MIC
I've had this for about 5 years. Very good performance up until about 6 months ago when it began to crackle, ,break up, and cut out. My question:
Is it worth repairing (out of warranty) or is there an easy fix?
  • kayser9soze Oct 27, 2008
    My mic is barely over the year old and it's started crackling..was flawless up until this past weekend. I had to replace it with an audio technica mic in the process of either getting it fixed or breaking down into fits.
  • Anonymous Apr 01, 2009
    mine was working fine, a couple days ago started to crackly randomly, maybe one transient in 20 seconds or so. Is there a fix? What happened?
5 Suggested Answers
PcExpert
  • 293 Answers
SOURCE: NT1A no signal in sequencer
try cleaning your plugs before inserting them into the machine. a dry clothe will do nicely. polishing the plug heads in a twisting motion.
Posted on Sep 13, 2007
jerseymark
  • 358 Answers
SOURCE: I'm buying a Rode NT1A,
Hi, what else do you do think you will need? I don't think you will need any other thing except that before you use the mic, the switch for the phantom power on the microphone is to be activated .Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantom power on the mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
That all you will need .
Thanks for using fixya....
Posted on Oct 21, 2010
  • 4 Answers
SOURCE: Rode NT1A: i got an adapter
The reason it is not being picked up by your PC is because the NT1A is a condenser microphone and it requires an audio interface that can supply phantom power (48V) to get it powered up. Without phantom power, the NT1A won't work. You many need to buy an external audio interface that provides phantom power to use the mic. Hope that helps.
Posted on Mar 05, 2011
krb55
  • 604 Answers
SOURCE: i got a pre-amp (Focusrite
the process of elimation will help you to solve your issue. first plug the rode nt1 (great mic by the way), into a good pa head or something you know works, of course you will need to have a pa that gives you phantom power. if the mic works then move on to the preamp. try it in the pa too, if it works move on to the m-audiophle and plug a line level signal into it (a cd player or mp3 player for instance) it this works then you have determined that everything works and you don't actully have a problem other than switching, Also try plugging your mic into the M-audiophle directly and see if thaat works ( don't know if that provides the 48 volts, if it doesn't than you will have to get a phantom supply to plug into first. good luck
Posted on Mar 17, 2011
Rode Nt1a Beep Sound
Does the background sound get louder or fainter when you change the mic gain on your mixer? If it depends on your XLR cable, it may be radio interference, and you need to make sure you use top quality shielded cable, and that you're wired "balanced".
Jun 04, 2015 | Rode NT1A Professional Microphone
My Rode NT1a stopped working. I checked preamps
Repair of this mic is not something you can do yourself. This sort of failure is common, and I can repair it.
Sep 20, 2013 | Rode NT1A Professional Microphone
Rode NT1a Hum and cut out
This is a typical failure of the components. I repair this sort of problem on a regular basis. Condenser Microphone Mod Service
Oct 10, 2012 | Rode NT1A Professional Microphone
Static noise
This is a problem that's not too uncommon. First, you need to determine if the mBox is at fault, as they can be noisy. Test it with another mic.
If the mic is indeed at fault, and is under warranty, I advise sending it to Rode for repair. Otherwise, I can can perform out of warranty service on any Rode mic.
May 22, 2012 | Rode NT1A Professional Microphone
I got a pre-amp (Focusrite Platinum Trakmaster Pro) with phantom +48v. i got an M-Audiophile 2496 installed to the comp. and a mic Rode nt1A. Eveything is plugged in and installed and iv'e...
Mar 17, 2011 | Rode NT1A Professional Microphone
Rode NT1A: i got an adapter so i can input it in the mic input the pc says an audio device has been put in but i cant find it anywhere! please help me i also have an Acer Z5710
Mar 03, 2011 | Rode NT1A Professional Microphone
I have been using my nt1a 4 a yr now... i would always keep it in the box along with the moisture absorbing crystals supplied at the head of the mic. it was working just fine... a month ago i didnt keep...
Most likely, this is typical component failure. After a year, which is the average lifespan of Chinese components, failures like this become increasingly common. The mic will have to be professionally serviced.
Feb 05, 2011 | Rode NT1A Professional Microphone
My Rode NT1a is not working, I have checked the phantom power and all cables which are ok.
If it is under warranty, I recommend sending it to Rode for repair. Otherwise, I can service any Rode mic. Condenser Microphone Mod Service
Jan 17, 2011 | Rode NT1A Professional Microphone
When I switch on my Rode NT1 - A mic - it is OK until I speak into it and it cuts off for about 20 mins. Then it comes on - then it cuts off when I speak or sing. Can you advise?
I had the same issue. The sound would fade and then go dead.. The preamp in the device I was using wasn't strong enough and also the phantom power seemed too low to sustain the microphone. After adding a TUBEPre by PreSonus, all of the issues went away and I was shocked to hear how good this microphone really is. Was the issue low phantom voltage/? or a lousy preamp? All I know is , after adding a preamp all of the problems went away.This has to be the best microphone I have tried in this price range.
Oct 17, 2009 | Rode NT1A Professional Microphone
Rode NT1A Professional Microphone Logo
120 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
