Question about HP OfficeJet k60 All-In-One InkJet Printer
Solution to fix prolem with machine
I have a problem with my all in one hp officejet. Once I turn on the power on the machine it makes a beeping sound. I am unable to send a fax and receive faxes
  • 24 Answers
Line interface unit is broken beacuse of which the beeping sound comes up. It tries to intiate however fails as a result the sound comes up. Need to replace the printer.
Posted on Feb 06, 2008
Error and loud beeping
Hi Cathy, Unfortunately I am not familiar with the J5780 machine. Sorry I could not help. Kind regards Printdesigns
Nov 29, 2011 | HP Officejet J5780 All-In-One Printer
Whe i turned on my hp officejet 5610 all in one, i have the error message "error Oxd05d010d Reset Power" with a long beep
Try resetting the printer.
1. With the power turned on on the printer; disconnect the USB cable from the printer.
2. Disconnect the power cord from rear of printer.
3. Wait 60 seconds.
4. Reconnect the power cord; if printer does not turn on, press the Power button.
5. If you receive a prompt to print a calibration page, do so.
6. Reconnect USB cable to rear of printer.
If this does not resolve the problem, suggest you try running the HP Print Diagnostic Utility:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&lc=en&dlc=en&cc=us&site=null&product=441125&key=null#N104
Dec 22, 2010 | HP Officejet 5610 All-In-One InkJet...
I have hp dc7100sff desktop computer the prolem is that when i turn computer on the computer show me red light and give beep continous & not giving display...plz help me to solve this problem
please open the tower of the computer from the side and clean the RAM of the computer using a soft cloth and make sure no dust is present .Put the stick in the same way back and close the tower .
The problem should be resolved
Nov 11, 2010 | HP Compaq dc7100 PC Desktop
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
FAX BEEP COMES ON EVERYTIME SOMEONE CALLS
Call Hp up and they will send you a cord that you have to have.
May 28, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My HP Officejet 6310 makes a squealing noise when printing, like the roller needs oiling-any suggestions on what to do?
turn off the printer..connect the printer to wall outlet..and try to make a copy..if its still the same..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold OK and CANCEL button together..
3)while pressing these two buttons plug in the power chord to the back of the printer..
4)after you plug in the power chord do not release those two buttons..
5)keep pressing those two buttons till the screen goes blank..
6)once the screen is blank release the buttons and turn on the printer..
7)wait for the printer to get initialize..
8)once the initialization is complete..try to make a copy..if the printer is still making noises..then machine should be replaced..
let me know after you perform these steps
Mar 10, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
This has to be easy!
Kristin, please perform a power cycle, reboot your computer then once it is on, reboot the printer too, this will reinitiate printing capability of the device.
hope this helps
Aug 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet all-in-one
This issue seems with the scanner mechanism of the all-in-one. Once try to make a copy and check the result, of it still says scanner failure, then connect the all-in-one directly to walloutlet and then power cycle the all-in-one and then reset.
May 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet k60 All-In-One InkJet Printer Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
