Brother Intelifax 2920
We chage the toner on the machine because it said low ink and now it is saying no print???Please advise
  • Cis1 Dec 12, 2007
    We have used the book and it still reads UNABLE TO PRINT
  • 64 Answers
This sounds trivial but when you changed the toner did you follow the instructions that were included in the box?
Brother machines have to be doen a certain way or the page count on the cartrigde will not reset and will still say low/empty etc
Hope this helps
Pete
Pete@wedotoners.com
Posted on Dec 12, 2007
Brother 2920 display unable to print pleas help me
hi
check the cable connection
check if you have toner in
check the drivers
Jan 15, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
I have a intelifax 2920 Super G fax machine that has lines horizontally through the page, just one every 4 inches on the pages that are faxed in
This is a drum defect. You are going to have to replace the drum unit. I have seen this so many times I have lost count. The drum unit is the part that your toner cartridges are installed into. Just order one in and replace it. The lines will go away.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Brother IntelliFax-2920 Plain Paper Fax,...
How to replace in k
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
Oct 02, 2010 | Brother FAX-2920 Plain Paper Laser
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Changed the Toner in Fax Machine and Still reads "Low Toner"
First, the obvious
  • Did you gently rock the toner cartridge from side to side to evenly distribute the toner?
  • Did the cartridge "click" into place?(did lock lever pop up when it was inserted)
  • Did you replace the protective cover securely?
Another thing to check is cleaning the Corona wire inside by sliding the Blue tab back and forth several times. Important to return the Blue tab back to the "Home" position afterward.
If you've done ALL of these steps correctly, and the low toner message is still there, a service call is in order. Best of luck with your machine!
May 06, 2009 | Brother IntelliFax-2920 Fax
Changed the toner but it still says "unable to print"
Put the old tone back in machine. Does the problem still exist? If not try another new toner.
If it does then you may have a mechnical failure which will require a service center.
Apr 15, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Put in brand new toner machines says toner is low.
plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
248 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
