Question about Acer AL1916W 19" LCD Monitor
Monitor does not retain picture
When the computer and monitor is turned on, the monitor shows the screen picture presented by the computer for a few seconds, then the screen goes blank. If I turn the monitor off and on again, the same thing happens. I have also hooked the monitor to other computers without any change in the problem. The green"on" light does remain on.
  • 2 more comments
  • herghjjt Dec 08, 2007
  • xray-k Dec 22, 2007
    I have the same problem: turn on power to screen, stays on for 2-5 seconds,... black screen. Brand new monitor, please help, suggestions?
  • xray-k Dec 23, 2007
    xray-k again: I read several of the suggestions here on the board. I have tried the Hard Boot (removing the power cord, etc), removing the graphic card and reinserted it, checked the screen resolution etc. I am using a Mac G4 and I have been using a AL1916W as my main screen. This screen have been reliable and has worked flawlessly for more then a year. This new, 2nd AL1916W has eaten several hours of my day with no solution in sight. Any suggestions? Thanks in advance.
  • dmerchan Jan 10, 2008
    i do have the same problem, i turn it off and on while it shows image i press the empowering button and set another configuration (you only got 2 or 3 sec to do that) if it doesn´t work i repeat the procedure until it stays on
  • 32 Answers
Based upon so many people that have the same problem, it probably is a defect... I may call the manufacturer, chances are they are aware of the problem and are willing to replace it or tell you what to do.
I found the contact info here; http://us.acer.com/public/page11.do;jsessionid=4EA0E8447B0D219E50E60867ADA1D9E5.public_a_14b?sp=page74&UserCtxParam=0&GroupCtxParam=0&dctx1=25&CountryISOCtxParam=US&LanguageISOCtxParam=en&ctx3=-1&ctx4=United+States&crc=790373818
Acer America (USA only)
Acer America Corporation
333 West San Carlos Street
Suite 1500
San Jose, CA 95110
(408) 533-7700 – Phone
(408) 533-4555 - Fax
(408) 533-4574 - Sales Fax
I also found this part for monitor repair; http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Regards,
-Chester
Posted on Jan 11, 2008
Monitor will turn on but nothing shows up on the screen
If the monitor logo is present on start up, chances are the monitor is fine, but if the screen remains blank this is something for the service shop to handle.
Dec 28, 2010 | Trilogy T3-17B1 Monitor
Tip
Determine if you are having problems with your monitor or video card in your...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor with a friend, co-worker, or family member with a known good monitor. You can do this with either your computer tower or your monitor. Follow the two steps below:
1. Take your computer tower and plug it up to a known good monitor. If the computer boots up with no problems and you are able to see everything on the known good monitor, then your monitor is bad.
2. Take a known good monitor and plug in to your computer system. If the computer boots up and you are still having problems and getting a black screen or some message saying "no signal" then your are having problems with your video card.
Some common symptoms of a monitor going bad are as follows:
1. A humming or buzzing noise coming from your monitor.
2. Picture fades in and out.
3. Colors appear in various places on your monitor screen that normally would not be there. Most common colors presented are red, green, or a mixture of the two.
4. Picture presenting either light or dark and will not change no matter how much you change the color or tint setting.
5. Lines appearing on the monitor screen. These will look like the lines on a bad television.
6. Monitor takes longer than normal to present picture. This time can vary depending on how old your monitor is and how far into the malfunction phase it is.
Since your monitor works off the same principles as your television set, most the time it will present with the same symptoms as a television going bad. I hope this helps in your troubleshooting process to determine if your video card or your monitor is the one causing the problems. These symptoms apply to the regular monitor only and not necessarily an LCD monitor.
on Jul 07, 2008 | Acer AL1912 19" LCD Monitor
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
My screen only shows a picture for a few seconds
Try connecting a different monitor to your computer, to see if that monitor shows the same symptoms. If so, your computer, not your monitor, is the problem.
Try connecting your monitor to a different computer (desktop or laptop) to see if the problem "follows" the monitor.
Jul 17, 2010 | ViewSonic VX900 19" LCD Monitor
Lcd monitor goes black
Try a different monitor (a friend's) on your computer, if it works OK the problem may be with your monitor. If it does the same as on your monitor, the computer video card may be defective.
Try your monitor on a different computer (a friend's) etc. You will figure if anything or what is defective. Then you can decide to repair or replace.
May 31, 2009 | Apple Multiple Scan 1705 Monitor
X2gen 19" monitor
open the monitor there is a vertical ic which has small alluminium heat sink ckeck 12v supply to ic if present then remove ic & check 12v at same point if present then replace ic if absent then check 12v regulator ic if faulty replace it
Jul 20, 2008 | X2Gen MG19MY 19" LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
Acer AL1916W 19" LCD Monitor Logo
803 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
