Open your printer. Locate Waste Ink Pad inside in your Printer, on the right hand side are quite small. You can remove the pads & holder with a gentle pull. Using a tissue, soak as much as ink as possible and clean around the waste ink area. Be careful & Patient. Whilst the printer is disconnected from the main power. Press and hold the Power Button and reconnect to AC Power. Release the Power Button & Press the Power Button Again. Good luck! If i am helpful to you, please rate me. Thank you.
Comments:
Aug 31, 2009
- To clean your ink pads here is the procedure on how to do it. # Open your printer. # To protect hands from Ink wear thin latex (or similar) gloves. # Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side and are quite small. # You can remove the pads and the holder with a gentle pull. # Using a tissue, soak up as much ink as possible and clean the area around the waste ink area. # There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dryed and placed again. Be careful and patient. This is no understatement. On the iP1500 this requires the dismantling of most of the printer. Take a photograph (even with your cell phone) so you can trace back your steps. On the iP1500 the drive motor on the side (Just behind the waste ink pads) has to be removed to get to the main sponge. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs. # Carefully replace the holder and the pads. Close printer. # Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power. # Release the power button. # Press the power button again. Good luck!
Was this helpful?
Yes
No
Popular Solutions for Cannon Canon i960 Refurbished
The i960 does not print. The orange light flashes intermitent with the green non-flashing ight 7...
(More)
The i960 does not print. The orange light flashes intermitent with the green non-flashing ight 7 times. I think it needs an ink absorber replacement. The printer head also does not return to the center so that you can change the cartridges or do any testing.
Colors print as yellow or green. Hearts that should be red print as yellow. Magenta shows blank on...
(More)
Colors print as yellow or green. Hearts that should be red print as yellow. Magenta shows blank on the nozzle test. Several cleanings and one deep cleaning have not solved the problem. The ink cartridges have sufficient ink.
I have a i960 Cannon Photo Printer.When I try to print with just a black cartridge the printer works...
(More)
I have a i960 Cannon Photo Printer.When I try to print with just a black cartridge the printer works but does not print anything.
