Epson Stylus R265 InkJet Photo Printer Logo
Posted on Aug 31, 2009
Parts need servicing
Same problem here, send me the fix please.
[email protected]
Thanx
Btinternet rejected my password to obtain my E mails
If you normally use an email program like Outlook or Mac Mail, try logging in to your webmail. If you can see your webmail OK, then it's likely to be a problem with the way your email program is set up.
http://bt.custhelp.com/app/answers/detail/a_id/49512/c/7339/session/L2F2LzEvdGltZS8xNDc4MjExMzgzL3NpZC96SVllVUwybg%3D%3D
may need to reset password if you can't get into web mail
if you can check the authenication method you selected in the email program
from
http://bt.custhelp.com/app/answers/detail/a_id/9962/c/7339
IMAP incoming server option
Incoming Mail Server: mail.btinternet.com
Port: 993 (this should be automatically populated if you tick the SSL Encryption)
SSL Encryption: Enabled (but not STARTTLS)
Username: your email address including the @btinternet or @btopenworld.com part
Password: your btinternet password
Root folder/path:
POP3 incoming server option
Port: 995 (this should be automatically populated when you tick SSL Encryption)
POP from folder: By default, POP will pull emails from your Inbox
SMTP outgoing server
Outgoing Mail Server: mail.btinternet.com
Port: 465 (this may not be automatically populated on selection of SSL, so you'll need to check this)
Authentication: PLAIN
I have lost my password
Please, before you press send or answer, check the URL. Here we are on Fixya.com and not on PayPal or any mail site.
To solve the problem, contact PayPal support:
https://www.paypal.com/us/webapps/helpcenter/helphub/home
My email has been dropped please reinstate its buildtrain@ btinternet .com cannot read or send
sorry but we are not bt. I mention this in case you hadn't noticed the web address of this website called fix ya.
here is the website for bt Broadband TV phone home business
I cannot get or send emails. my server is not working
This indicates either an incorrect password or server settings. Make sure your account is setup as follows:
IMAP
Root folder/path:
Folder separator: . (full stop)
Please do NOT enable "secure password authentication" (SPA). It's not needed when you use SSL encryption and won't work.
If your IMAP client supports it, we recommend you also set up the following folders:
Trash
Sent Items
Drafts
POP3
Port: 995 (this should be automatically populated if you tick SSL Encryption)
SMTP
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Why cant i send emails from [email protected]
To be able to send mails, you have to be logged in to the account. Only then you can send the mail. But when btinternet.com, is a POP3 and STMP server provider, it could be you deleted the settings for the POP server or they are changed one way or another. Please check or fill in both server settings in your browser(s) see if they are correct, or renew them.
1helpful
'I can;t receive emails to my btinternet.com account but I can send them ok
This works for outlook 2013 but not sure if its the same for outlook.com....Go into the account settings and click on 'more settings' go to the 'Outgoing Server' tab and make sure 'My outgoing server requires authentication' is ticked. Hope this helps.
Hi my imei is 357400041273708. Can u please send me the restriction code to my email [email protected]. Thanks
you can get the restriction code for your phone either from your service provider or from other online providers like Superunlockcodes.com
Apr 30, 2012 • Cell Phones
Sending email
here are the settings for btinternet, if you use "outlook" you must manually configure them!
  • The POP3 server (incoming mail) is mail.btinternet.com
  • The SMTP server (outgoing mail) is also mail.btinternet.com
  • Both need your BT Yahoo! email address and password; you will have to tell your e-mail program that the SMTP server requires authentication.
  • The SMTP server can use either port 25 or port 587.
The most common fault is to provide your ADSL username and password when your BT Yahoo! username and password is what's required.
good luck and regards
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
