Question about Linksys Wireless-G WRT54GS Router (e125894)
Laptop connect laptop through router to my computor
  • 108 Answers
Most of the router configurations are web base, you have to use http compatible browser to connect router. basically you can try with internet explorer to connect.
Posted on Dec 06, 2007
Router shows good connection but no laptops in house show network
Have you successfully used this router before? Do you have EasyLink Advisor running? If not, install it from the CD and then, on each computor, open it, make sure it is running, click on the Actions tab, and click "Add more computers" and folow the instructions. Hope that helps!
Nov 18, 2011 | Linksys Wireless-G WRT54G Router
My Toshiba Satellite L305-S5921 won't connect wireless or wired to my internet it shows the net works and signals and can be connected to the router but ends up with local or limited service I've reset the...
Try disconnect the router and connect your laptop to the dsl modem. If there is connection then the router may have problems. If the problem persists then go to toshiba service center. They will certainly solve your problem. It might be that there are problems on hardware or drivers.
Jan 30, 2011 | Toshiba Satellite L305-S5921 Notebook
I connect the modem to the router, then router to the computer, the i cant get the internet on any computor, my laptop has wireless installed and i cant connect to any
Configure your network with the following
Modem - 192.168.1.1
Router:
eth0 192.168.1.2
eth1 10.2.0.1
Connections:
1. Modem to Router's eth0 (i.e your first ethernet port)
2. Routers eth1 to Switch (if any else connect it directly to computer)
3. Assign the your computer with
IP: 10.2.0.2
Subnet mask: 255.255.255.0
Gateway: 10.2.0.1
Do as above sure u will get connected.
Sep 21, 2010 | NetGear Computers & Internet
My computor says that i,m not connected to the
How is this "other computer" connected? Is it hooked up to your router? That might just fix the problem, if it is nogt connected. The Modem must be also connected to the router's WAN input.
Nov 29, 2009 | Dynex DX-E401 Router
Need to re-connect to linksys
connect to your linksys using ethernet cable try configuring your modem/router again. if this does not solve your problem reinstall your wireless driver in your computer.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Getting wireless computor and router back on line with desk top computor
1. Disconnect power from your modem and router
2. Connect an ethernet cord from your modem's ethernet port to your router's Internet or WAN port.
3. Connect another ethernet cord from a port on your router (labeled with a "1" above it).
4. Connect power to your modem and router.
5. I'm a little unsure about how you plan to connect your wireless computer to the router. The router you selected when you created this question is not wireless-capable.
If your router is wireless-capable, go to the wireless computer. Follow the instructions for your operating system below.
Windows XP
1. Right-click on the My Network Places icon on your desktop, and select Properties.
2. Right-click on Wireless Network Connection.
3. Right-click on View Available Wireless Networks.
4. Double-click on your network from the list that appears (it should be called "linksys" if you didn't change the name).
Windows Vista
1. Click on the network icon on the lower-right of your screen (it should look like two computers with one behind another. It might have a red "X" over it.)
2. Click "Connect to a network" (it also might be labeled "Connect or disconnect")
3. Double-click on your network from the list (it should be called "linksys" if you didn't change the name.
Mac OS X
1. Click on the AirPort menu in the upper right of your screen (it looks like "("s turned on their side).
2. Click on your network in the list that appears (it should be called "linksys" if you didn't change the name).
Sep 30, 2008 | Linksys EtherFast Cable/DSL Router
Can't connect wirelessly to Belkin Router
have you customized the wireless settings of you router (e.g. ssid, wireless channel, wireless security)? if not, try to change your router's ssid or the wireless channel. it could be that some wireless devices are interfering with your signal.
hope this'll help you.
ciao!
Jun 20, 2008 | Belkin (F5D5231-4) Router
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
