Question about Canon Rebel XT / EOS 350D Digital Camera
Trying to take pictures in low light conditions inside a theater.
I was asked to take some pictures during dress rehearsals for a local theater performance. The lighting they use is very old. I have a Canon Digital Rebel XT. I used a 28-90 lens with a tripod. When I set my ISO at 800 and 1600 some of the pictures looked fine but some of the picture turned out blurry. I got a lot of blurry hands and faces. Then I changed my ISO to between 100-400, almost all the pictures turned out dark. I would like to use the manual modes.( M, AV, TV) Does anyone know what the best setting to use in this type of lighting conditions?
  • Orffin Dec 06, 2007
    I've recently had the same problem and I'm eager to try the solution listed here. How slow of a "slow shutter speed" would you reccommend?
  • 108 Answers
When you use high ISO like 800-1600 it will create big novice on image, and when you using law ISO it will be dark for sure.
so the solution is switch cam to TV mode and put into very law shutter speed and use ISO 200-400,make sure you are connected to tripod or else you will not get fine results with law shutter speed. point is when you use law shutter speed camera will take more light to censor even with law ISO your images will be perfect.
Posted on Dec 06, 2007
  • Saptha Wanniarachchi
    Saptha Wanniarachchi Dec 06, 2007
    Hi Orffin,
    its all depend on the amount of light you getting on hall, also the action that you going to capture, if you trying to capture something like walking model you need aprox 20-60/sec but if you get change to hold object more than few sec's go for less than 10
Any good tips on how to buy a wedding dress?
Do some research & choose stules that suit your body shape. Have a budget in mind & keep an eye out for bridal salea AmanStino QUICK CHARGER 3 0 USB charger Multi Port Intelligent USB Wall...
Feb 27, 2013 | Clothing
I am going with my mum to try on wedding gowns next week. Will they let me take photos of the dresses I try so that I can send them to my sister for her opinion?
Most places won't allow photos to be taken until you have actually bought the dress. This stops people from copying the designs and usually they are quite strict about this rule.
Jan 10, 2013 | Clothing
Error f61 in panasonic sht540
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
May 28, 2010 | Panasonic Audio Players & Recorders
JCM2000 DSL100 No Sound
Not likely to be a fuse. The bane of electrical amps are the connectors.
Often the speaker and more commonly the input 1/4 inch connectors go bad. Sometimes caused by side loads when cables are yanked or tripped over.
Be careful of running amps IF the speakers are not connected OR have bad connectors or cables. You can arc over the tubes or pop transistors.
Get a cheap Volt-ohmeter from HarborFreight or Radio Shack and test your cables and connectors.
For a tube amp, your should find relatively low resistance at the speaker connector (certainly under 20 ohms). Do this with power off.
Sep 09, 2009 | Marshall Music
How to flash the cell phone
Follow these steps; Select Options > Image setup > Flash > On/forced to use the flash.
If the flash is set to Off or Automatic during bright
conditions, the flash still emits a low light when an image
is captured. This allows the subject of the picture to see
when the picture is taken. There is no flash effect on the
resultant picture.
Aug 27, 2009 | Nokia N72 Cellular Phone
Blurry Shots
Your best bet is to either go to the store where you bought the camera or consult your manual which was surely in the box with it. There should be a tutorial on how to 'perfect' either the focus or the stabilizer lens. If not, then you should consider going to the store and ask them.
Feb 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Powershot SLR takes fuzzy photos
you need additional flash or brighter light to click in low lighting condition. In order to compensate for low light conditions, the shutter goes slow and therefore you get fuzzy pictures.
Another way is to click on movie(video) mode and then atleast you can see them moving around as well as while editing, you could take out some pictures from the video( though on lmuch ower resolution).
Jan 28, 2009 | Canon PowerShot S5 IS Digital Camera
Taking pictures with low light
on the top dial position to p........ if neer a window during daylight dial to gide and select shooting into backlight then over to fill in flash.........also indoors and portrit with flash helps
Dec 13, 2007 | Olympus SP-510 UZ Digital Camera
Red vertical smears on LCD display and on playback
Your camcorder is on a list with potentially defect CCD light sensors. Sony is replacing them free of charge. Go here for the link and free mailing label:
Dec 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
Low Lite LCD Use
The LCD is completely WYSIWYG and if you can't see anything through the LCD then the picture you take will be black too. If you are outside and open the shutter really wide you will see the LCD go white as the light overpowers the exposure. The best thing to do is to increase the ambient light in the area by turning on every light. You will still use the flash for the picture but you need to get more light on the scene to see through the LCD. For what it is worth, an optical viewfinder probably wouldn't do any better job in those situations.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
2,369 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
