Question about GE JVM1650 1000 Watts Microwave Oven
SpacemakerXl Microwave Oven JVM1650/1651
Once in a while my Microwave shutoff. I than need to unplug and wait about 10 min. and plug again to have it work. I think I need to cahnge my Charcoal Filter. What do you think?
  • 1 more comment
  • Anonymous Dec 16, 2007
    My 1650 will shut off as well. Starts cooking for about 10 seconds then it looses power. I have to reset the date/time and try again. Sometimes it will work. I just bought it about a year ago.
  • NSWS Jan 22, 2008
    I have the same problem with my GE JVM 1653 SH 01. It works for 3 -5 seconds then shuts down. I have to reset everything but it still isn't working. It is only 2 1/2 yrs old. I this something I can fix myself?
  • skitrees Aug 28, 2008
    I have the same problem (JVM1650) where it starts to cook and then behaves like there was a power loss. I set date and time then it sometimes continues to work. Seems to be getting worse. My mfg date is August 2004 though.
    I just tried unplugging it overnite and will see if that helps.
  • GE Master
  • 9,098 Answers
The magnetron may be failing or overheating.
There is a known issue with many GE models.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin at
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 06, 2007
Solution-GE spacemakerXL microwave oven model:JVM16505H01
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
Microwave is locked up
Most microwave ovens are like computers, they lock up and ocassionally need to be "re-booted", or re-powered. 1. Simply unplug the oven, then wait about 10 seconds, plug it back, and check to see if has unlocked itself. If not, continually press the clear or reset button. If that doesn't help, you'll have to get the model number and manufacturer from the label inside the microwave oven.
Jan 28, 2014 | Kenmore 66469 / 66462 / 66464 Microwave...
GE SpacemakerXL Microwave Oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
SpacemakerXL microwave oven JVM 1630 turntable in microwave not working
Jan 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microware shutoff after ~4 min of cooking
Return it for warranty repair or replacement. Does the blower motor operate?
Sep 08, 2009 | Maytag MMV1153A Microwave Oven
I cant turn the microwave oven on without the fuse cutting out
If you got the interior of the unit wet you may just wait a couple of days for it to dry out and it will be ok again. You may also plug your microwave in to another outlet, one that still works when the fuse that blows is unscrewed.
Finally you have a 1000 watt microwave which translates to using 10 amps of power. If you have a 15 amp circuit, looking at the number on the fuse, and you have other things plugged into that circuit like a toaster, toaster oven, coffee pot, hair blow dryer, etc, you may simply have to unplug something else to provide your microwave with the power it needs. good luck.
Aug 16, 2009 | Daewoo KOC-925T Microwave Oven
I have a GE SpacemakerXL Microwave Oven Model JVM1340. The pad is unresponmsive. When pluged in I get a line of eights and then get the message F 3.
Thanks for the opportunity to help! To see if this fault can be cleared, do the following:
  1. If your unit is plugged into an *outlet (most times, this is located over your microwave in small cupboards).
  2. If it is, unplug the cord and wait about 30 seconds.
  3. Plug your microwave back in and see if the panel now works.
  4. Go through all the initial setups such as setting the time.
  5. If the fault does not reappear, then you are good to go. If the fault reappears, you will have to call service or replace the product.
*If your unit is hardwired, find the circuit breaker and turn it off for 30 seconds, then turn the power back on.
If you find my assistance helpful, please rate my service. Thanks for using
Jan 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
312 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
