Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
MIxer quit working while mixing 3 batches of oatmeal cookies
I have a professional 6 model Kitchenaid stnd mixer. I have used it for the past 5 years to mix multiple batches of think cookie dough. the first triple batch I made this year it has quit working.
I did start smelling hot, and then it shut dowm. I though maybe once it cooled off it would come back on. But it has not. I was wondering if this model has a reset button.
Also do you know how long the warranty is on this model?
Thank you for your help.
Vannetta
  • vmcdowell Dec 06, 2007
    I will refer back to the post above.
  • Anonymous Mar 12, 2009
    My KA mixer has done the same thing
  • 135 Answers
Hi. Kitchenaid's warranty is 1 year.
Most likely, the plastic transmission housing has failed, causing damage to the working parts inside your mixer. Take it to a local repair place and have them work up a quote to repair it. It will take at least a month to get the parts.
If this solution has assisted you, please rate it. ricardok45
I
Posted on Mar 24, 2009
Kg25h0x mixer
Type not found at Kitchenaid. no_image_available_kad_71x71.png 5-Qt. Stainless Steel Bowl with Comfortable Handle
5-Qt. stainless steel bowl with comfortable handle offers enough capacity to mix dough for 9 dozen cookies, 4 loaves of bread or 7 pounds of mashed potatoes in a single batch. The bowl is also dishwasher-safe for quick and easy cleanup.
Mar 04, 2014 | KitchenAid Food Mixers
No rotating movement from the mixer, only fast clicking sound after beater was lodged.
This is an excellent mixer and worthy of a professional or DIY repair.. You stripped a gear inside the mixer that is there just for that reason. Now the machine requires a tear down and replacement part. if you can post the model number we can advise on how to do it. If it is the new pro series model they cost between 4 and 5 hundred new to buy, the repair is going to cost between 80 and 100 dollars by a professional or about 30 dollars by you.
Dec 31, 2012 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I just bought a new kitchenaid mixer yesterday to bake cookies for a cousin's baby shower. I love to bake & usually do things by hand, but loved the neighbor's when I tried it. When I opened the box I...
Considering there was no manual, the unit may have been refurbished. If it was, the fact that is must, by law, have a clear indication on the box that it has been refurbished.
Kitchenaid makes a high quality product, so you might want to contact them directly. I'm sure they'll do the right thing.
Oct 22, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I have a kitchenaid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
May 14, 2010 | KitchenAid KP2671 Professional 6 Series...
Which kenwood mixer to buy?
Hi. Congratulations for researching mixers. I wish I had before I bought my Kitchenaid HD Pro. All mixer manufacturers over-rate their products. Goto www.consumeraffairs.com and do a search for each mixer you are considering. Most mixer failures are caused by mixing heavy cookie or bread doughs. Although manufacturers claim that their mixers can easily handle these doughs...They cannot! My Kitchenaid self-destructed after 30 batches of bread dough. "For the way it's made"! Indeed! I solved my problem by buying a Hobart N50 mixer. It's a 5qt. and handles anything I throw into the bowl. I bought mine used, and refurbished it myself. New these units cost $2,035.00 USD.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 15, 2009 | Kenwood KM800 Major Classic Stand Mixer
6qt Pro Kitchenaid Mixer not mixing
Hi. If you goto the Kitchenaid website you can do a search for the parts catalog for your model of mixer. Download the catalog. It will assist you in disassembling your mixer.
Remove the silver band around the top of the mixer. Remove the top cover and look at the top front of the machine and locate the transmission housing. If it's plastic, carefully inspect this housing for cracks. If you find cracks in this housing, IT is the source of your troubles. This cheap piece of plastic has no business being installed in a high-priced mixer. Your machine probably failed when you were mixing heavy bread dough or cookie dough. When this cover cracks, it can strip the worm gear shaft, its bearings and the bearing seats. It happened to me, and many thousands of other users I expect. Insist on a metal trans. housing for your replacement.
You may be able to have Kitchenaid pay for these parts even out of warranty, just don't tell them that you opened it up. Take it to an authorized repair place and let them assess the damage. Use their estimate to confront Kitchenaid. Be persistent in your complaint, keep asking for a manager to get involved in your case. They paid for my replacement parts even though I was 5 months out of warranty. The higher up you go in the management dept., the more likely you are to have them pay for your parts.
Once repaired, sell it ASAP!
Feb 16, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
253 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
