Question about Garmin StreetPilot C330 GPS Receiver
No power I can't seem to get the power when i connect it to car charger and seems no power at all even when I use its battery.
  • Anonymous Dec 07, 2007
    Mine shuts off after a few minutes - doesn't seem to charge. I'm returning
    it - Have only had it 2 days - Cell phones charge fine from this same jack.
    Either the garmin or the charging cable is defective.
  • Anonymous Dec 17, 2007
    I'm having the same problem with my new StreetPilot, purchased the day after Thanksgiving. I've tried charging in the car and using the USB cable without any luck.
May need new backup battery but seems odd being new unit but you never know .
Posted on Dec 19, 2007
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
MY CANON CAMERA 2000 PS turns on & then off immediately
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little rubbing alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Aug 28, 2016 | Canon Cameras
My laptop indicator light doesn't come on when plugged in and battery does not charge.
problem is with your motherboard-section for power switch and charging battery,probably IC for power control,charging...
Sep 12, 2014 | Computers & Internet
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
No power when trying to start
No power as in it won't even crank over? Is the battery ok? Try jumping it or putting it on the battery charger. If that seems ok, maybe a bad connection at the battery post. Does it even click or try to do something.
Feb 11, 2012 | Cars & Trucks
It will not turn on and the charger doesn't seem to work even though it is properly plugged in.
remove the battery and unplug the power adapter. press power button for 30 sec. then connect power adapter. press power button.
Mar 21, 2010 | Computers & Internet
Netbook acer one not recharging the battery
Your charger might be dead, check his output with a voltmeter if you get some juice. It should be around 19 Volts. Then it might loose his power with a charge (when you plug it onto your laptop) so you can try to connect a car light bulb to it . If get light then probably the motherboard of your laptop has issues, if no lights then you can replace your charger.
Cost in average 45 USD.
good luck
Jul 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dead battery on tahoe 2005 - now no power to ignition
provided you disconnected the battery before you charged it, its probably just a new battery you need, but if you did not diconnect it you have probably done damage to the starter motor and maybe the alternator and god knows what else
Jun 13, 2009 | 2004 Chevrolet Tahoe
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
