Question about Ovens
Oven not working
The bottom oven is not heating up. The Fan is working but there is no heat
  • 1 more comment
  • Anonymous Jul 06, 2008
    every thing is working but not the oven, It show an error F3E0, what does that means
  • Hotpantsrita Aug 23, 2008
    The fan is working there is some heat but not the right temperature. I put the temp up to 200c but it doesn't reach that temp, just warm.
  • antappliance Nov 19, 2008
    kebc208 lower oven won't work, the fan works, but no heat, no error code on panel, panel works.
    Sergeant:
    Champion:
  • 262 Answers
Chances are that the element is bad but with out more info on like what kind of thermostat you have if digital display if any codes like f-1 show this would be first thing i look at check power at element 220 volts should be at element if so element is bad (replace) is not you need to find the wiring diagram and follow it back and check voltage and ohms you will need a volt ohm meter for this.
good luck
Posted on Dec 08, 2007
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 | Ovens
My Neff eletric oven works on top and bottom heat, but does not heat up on the fan setting fan. It heats slightly and the fans works but it does not reach temperature.
You need to replace the oven element
This is located at the rear of the oven compartment behind a removeable cover, it is usually circular in shape
Jan 26, 2011 | Neff B1421 Electric Single Oven
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
My bottom oven is not heating up?
If it is an all electric fan assisted oven, and the fan is working o/k, then the oven element has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Dec 09, 2009 | AEG Ovens
Smeg fan assisted oven not heating up , top oven works fine but main bottom oven doesnt heat up at all but fan working fine many thanks
So long as fan is working o/k, then all you need to do is replace the oven element at rear of oven
Please rate my solution.
Thanks
Nov 10, 2009 | Ovens
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
293 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
