Question about ViewSonic G90fb 19" CRT Monitor
Viewsonic E53 monitor
I have viewsonic E53 monitor & it suddenly did not show any thing on screen, but it show the power indicator light(green)when in turn on the monitor,accidently picture came to screen & after few minits it automatically turned off. after that even it does not show the power indicator light. from inside the monitor little sound come out when it turn on
    Problem Solver:
  • 11 Answers
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Posted on Dec 06, 2007
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
Vp2000s:Solid green LED with black screen
Please read below before DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 17, 2010 | ViewSonic VP2000s 20.1" Flat Panel LCD...
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
Viewsonic has trouble turning on-- seems to backlight (screen lights, makes an electronic hum), and then go to dead (yet the green power indicator stays on).
Hi, well if this is the inverter board, then its probably more cost effective to buy a new screen, same thing if this is the cathode lights. Reason for that is the technician will charge to replace, so cost will get anywhere from 50 and up. Only one question, how many years old is it? I do believe Viewsonic has 3 year warranties.
Nov 01, 2009 | ViewSonic VP171B (Black) 17 in. Flat Panel...
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Hello - I have had a viewsonic monitor for 4 years, and suddenly the computer screen has gone black and will not turn on The green power light is on, all plugs are in correctly - please advise
The green power light would indicate that it knows it is hooked up to a computer, this is even more true if it turns yellow when you power down your computer. Can you plug this into another computer, or plug another working monitor into your computer? This will eliminate your computer as the problem.
Check you video cable, have you had it off before the monitor quit?
If it is still not working, at best you are looking at a cold solder joint, I have seen many monitors taken out by them and have fixed a few. I would sugest this to you only if you are aware of the high voltages that can be found in crt devices, even when not plugged in.
If you have not worked with highvoltage circuits I would suggest looking for a new or used one.
Used CRT's are give them away cheap now. Check your local want ads and craigslist.
Aug 07, 2009 | ViewSonic E70f 17" CRT Monitor
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
View Sonic monitor
I have Viewsonic 15" CRT Monitor (model E53)
When power ON, ther is only a colour patch appears on the middle of the screen . I observed some resistors and three transistors in horizontal sections were burnt.
I cannot read the real values of them because they are burnt.
Please kindly can you tell me those real values in that section.
Jun 13, 2008 | ViewSonic Computers & Internet
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
ViewSonic G90fb 19" CRT Monitor Logo
223 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
