Question about Numark BATTLE PAK v.4 Turntable
My tunrtable spins backwards :S
Ok..i have a set of turntables. one runs fine, and the other is not spinning forwards but now spinning backwards and very fast! and the stop start buttons also dont work on this deck.. any suggestions?
  • Anonymous Aug 06, 2008
    i have the exact same problem with these tables, got them used with a really nice mixer - dxm06, one works great, other spins in reverse at unreasonable speed, the start/stop does work, its just that it takes so long to slow down because the intense reverse speed, did the new motor correct the issue?
These motors are quite cheap. You can open it up yourself and see if any resistors are burned up. If not, contact numark parts dept and order new motor. quite easy to install.
Posted on Feb 09, 2008
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Turntable spinning backwards
Defective control PC board. take in for service
May 06, 2008 | Audio Players & Recorders
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
If it is a direct drive TT then it uses some electronic circuitry to control speed and it sounds like that circuit is having a problem. Possibly the actual driver IC for the TT motor has gone bad. Good luck.
Feb 13, 2007 | Vestax Pdx2000 Direct Drive Turntable...
Numark BATTLE PAK v.4 Turntable Logo
317 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Morne Olivier
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
