2001 Olds Silouhette - The blinker on the dash clicks fast when I have the right blinker on and the brake pedal depressed. Also, the driver side tail light alternates blinking from the turn signal lamp and the top and bottom tail lamps.
NO PROBLEM TURN ON THE RIGHT BLINKER THEN WALK AROUND THE CAR MAKE SURE FRONT AND REAR BULBS ARE FLASHING... IF YOU HAVE A BULB OUT YOU WILL NOT OFFER ENOUGH OF A LOAD TO THE FLASHER... WILL CAUSE IT TO FLASH FAST... IF OK THEN MAKE SURE THE PROPER BULB NUMBER ON BULBS AND MAKE SURE CORRECT BULBS USED IN VEHICLE.... IF OK CHANGE FLASHER
