Question about Cosmi Greeting Card Magic for PC
Coverting dtp file to pdf for printing
How do I convert the dtp file to a pdf so that I can email my greeting card to OFFICE DEPOT to print.
0 characters
1 Points
How to convert a Page maker file into PDF formate. I am using Page Maker 7.0 and Adobe Acrobat Distiller 6.0. And I am using Samsung Printer drivers to convert page maker to post script.
Go to print, select the printer as ADOBE PDF on my document\*.pdf, then the PPD as ACROBAT DISTILLER ****.***, and set the paper size, etc final go to print, then give file name for the pdf.
Mar 30, 2015 | Adobe PageMaker 7.0 for PC
When I attempt to convert a word document into an PDF file I get a message "missing PDF maker files" I'm given the option to say yes or no to "do you want to run the installer in repari...
From the info you provided, seems like your Adobe Acrobat Professional wasn't installed properly or there are some missing files.
If you have the installation file, try installing the software again.
(When you click on Yes, nothing happens because adobe cannot find the Installation/setup file on your laptop.)
If you do not have the Adobe installation files, as an alternative download CutePDF writer. Its free and hardly takes any space on your pc/laptop (<4MB)
Direct Download Link for CutePDF
Once downloaded, install the software and follow the steps below:
1. Open the Word file you want to convert to pdf
2. try to print it
3. before printing, the time when u have to select your printer, select Cute PDF Writer as shown in the image below
4. Click on print
5. The Word document will be printed as a PDF file and you'll be asked where you want to save it :)
6. Choose your destination.
7. When the printing is completed, you can open the pdf file in Adobe PDF reader
* You don't need a printer to do this
* You can follow the same steps and print excel/powerpoint files to pdf (or any other file type that you can "print")
Hope this helped!
Mar 31, 2011 | Adobe Acrobat 7.0 Professional
Just installed adobe acrobat 6.0. Whenever it try to convert a word file into PDF it says, there is a problem and has to run in 'repair' mode. It then instructs me to restart the computer once it has...
May be your converter is first trying to locate some specific version of Acrobat Reader and then do the conversion and Acrobat 6 might not be the required version.
You can try PDF printer and you just have to do print of any word file and it will print the file and save in form of pdf document
can try one such printer
May 17, 2010 | Adobe Acrobat 6.0 Professional for PC
I can't covert a project to PDF
You can reinstall pdf converter,or you can download a new pdf converter.I use advanced all to pdf 5.0,it is pretty good.Converted quality is fairly good: with text content, page layouts, images,and text hyperlinks preserved.I chose it because it is a standalone
application, I could run this program independently and needn't extra install Microsoft Office or Adobe Acrobat which costs hundreds of dollars.
Oct 06, 2009 | Broderbund The Print Shop 15...
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
PDF producer
You can use another pdf converter,there are many pdf converter in the market. Compared to other versions of pdf converters,i find Advanced PDF To word more appealing as it more faster to convert a huge PDF file to .doc without any quality lost, it also has more configuration option.
Sep 19, 2008 | Databecker PDF Producer for PC
Cosmi Greeting Card Magic for PC Logo
62 people viewed this question
Top Cosmi Graphics Publishing, Design & Multimedia Software Experts
Andrew Taylor
Andrew Taylor
Are you a Cosmi Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
